Fog lights not getting power, What else to check? |
saigon71 |
Dec 15 2018, 01:27 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power.
What are the next logical things to check? Do the fog light switches go bad? Thanks. |
oakdalecurtis |
Dec 15 2018, 03:33 PM
Oakdalecurtis Group: Members Posts: 1,328 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Bet money that Dick is right, you have the high beams on. If you’re any good at electrical, rewire the fog lights to an independent switch and relay so you can operate them separately from your headlights. I use my foglights that way as daytime running lights. (IMG:style_emoticons/default/beerchug.gif)
porschetub |
Dec 17 2018, 11:50 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Bet money that Dick is right, you have the high beams on. If you’re any good at electrical, rewire the fog lights to an independent switch and relay so you can operate them separately from your headlights. I use my foglights that way as daytime running lights. (IMG:style_emoticons/default/beerchug.gif) Done for safety reasons,in my country you can't have it anything different. Would like the daylight setup but not an option for me bugger it. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:29 PM |
