Fog lights not getting power, What else to check? |
saigon71 |
Dec 15 2018, 01:27 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power.
What are the next logical things to check? Do the fog light switches go bad? Thanks. |
Spoke |
Dec 18 2018, 09:30 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
My fog lights don't work on either side. After trying different bulbs, I tested for power with a VOM - no power. Next, I swapped the fog light relay out with several others...still no power. What are the next logical things to check? Do the fog light switches go bad? Thanks. Do your high beams work? If the one high beam that powers the fog light relay is burned out, the relay will never close and power the fogs. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:23 PM |
