Correct lug bolt finish?, Fuchs 4-spoke |
bbrock |
Dec 19 2018, 02:55 PM
Mine are rust and green paint. The tech who did the hub centric recall apparently got carried away and blobbed every frickin' bolt with paint. Any trace of original plating is now gone and I'm trying to remember how they were finished so I can have them replated. Chrome? Nickel? Other? (IMG:style_emoticons/default/confused24.gif) I seem to recall they weren't too shiny but that may be because they were already tarnished when I got the car, or just bad memory.
davep |
Dec 19 2018, 03:21 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
My belief is that the steel bolts were first copper plated, and then cadmium plated.
If you have ever seen corroded copper with a bluish green color, then you should recognize the coating on the bolt as the remains of the copper plating. This is similar to the "triple Chrome" plating on bumpers. First a layer of copper is plated on the steel, then a layer of nickel, and finally a layer of chromium. The copper bonds readily to the steel. This allows a better adhesion of the nickel. Finally the chromium protects the nickel layer from corrosion. The bright reflective silver color you see is the nickel layer, while the chromium is so thin as to be transparent. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:08 PM |
