| pdlightning |
Dec 21 2018, 11:47 PM
Pdlightning ![]() ![]() Group: Members Posts: 211 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California
I have read when modifying a 915 trans to be installed in the V8 914 that to be sure to shift the transaxle into all the gears after the ring gear is flipped - you will notice that one of the internal shifter rails will need to be shortened - just enough to clear the ring gear.
Ring and pinion sets (4.43, 4.38, 3.88 and 3.10 ratios). As I remember, I got the 3.10 ratio as instructed. Any 914-8 or 914-6 mod people that can comment on this? If this is true, I have to remove and modify my trans again before attempting to drive the car. Also, if it makes a difference, the ring and pinion that is installed is a higher geared for better RPM drivability at top speed with the LS mod. Thanks (IMG:style_emoticons/default/headbang.gif) |
| GeorgeRud |
Dec 23 2018, 12:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Did you use the Wevo, Vellios, or other kit for the conversion?
| mepstein |
Dec 23 2018, 01:23 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,931 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Did you use the Wevo, Vellios, or other kit for the conversion? I used a cable shifter for the 915 and the now, nla trans hanger from PMS. Only issue I have is I will need a custom set of mufflers from Ben since the cableshifter sticks too far out the back of the trans to run a normal exhaust. |
| pdlightning |
Dec 23 2018, 10:26 PM
Did you use the Wevo, Vellios, or other kit for the conversion? I used a cable shifter for the 915 and the now, nla trans hanger from PMS. Only issue I have is I will need a custom set of mufflers from Ben since the cableshifter sticks too far out the back of the trans to run a normal exhaust. Mine too is a special cable shifter with a MR 2 shifter box. Will be doing an engine/trans cradle to support the LS/915 combo. Also an electric water pump from Maziere. Just don’t know which model yet, maybe a 316. |
pdlightning 915 Trans use and Stated Modification question Dec 21 2018, 11:47 PM
mepstein Some clear without any mods, some need some work s... Dec 22 2018, 08:52 AM
pdlightning
Some clear without any mods, some need some work ... Dec 22 2018, 11:19 PM
rgalla9146
Some clear without any mods, some need some work ... Dec 23 2018, 09:33 AM
rgalla9146
Did you use the Wevo, Vellios, or other kit for t... Dec 23 2018, 12:57 PM
914dave I used the early Vellios kit. None of the shift ro... Dec 24 2018, 05:46 AM
pdlightning
I used the early Vellios kit. None of the shift r... Jan 12 2019, 06:56 PM
GeorgeRud Mine was also the Vellios kit and had no interfere... Dec 24 2018, 02:03 PM
Larry.Hubby I used a copy of the factory kit made by Vellios (... Dec 24 2018, 07:07 PM
pdlightning
I have read when modifying a 915 trans to be inst... Apr 16 2019, 05:55 PM
Jeff Hail
I have read when modifying a 915 trans to be ins... Apr 20 2019, 07:41 PM
pdlightning
[quote name='pdlightning' post='2705942' date='Ap... Apr 20 2019, 10:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th October 2026 - 03:18 AM |
