REAR SWAYBAR size question |
Marek |
Dec 26 2018, 03:58 PM
Newbie Group: Members Posts: 20 Joined: 27-April 15 From: Copenhagen , Denmark Member No.: 18,672 Region Association: None |
Hi Guys
Hope you all had a nice christmas hollyday I am in the Final stage of the Rear swaybar reproduction which I will have ready in a good few weeks I am making the set complete in 16mm and 18mm and to OEM specs ( rubbers and bushing will be OEM Porsche ) the kit will come complete , we are at 350-420 Euro range for a full kit , parts will be sold seperate also, also I made a plate so you dont need to weld the brackets on , more info will follow BUT My question is straight forward what would you put on 16, 18 , or do I also make a 20 mm Marek Attached thumbnail(s) |
914forme |
Dec 26 2018, 04:55 PM
Nice looking parts (IMG:style_emoticons/default/drooley.gif)
20mm or even larger, but you need to run a true limited slip differential if you want to keep forward momentum, as one of the rear will lift in hard cornering. If running open or torque biased I would leave it off. A flat cornering car does not it is mean a fast cornering car. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:34 AM |
