mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,900 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
I know @MarkHenry has talked about this but I want to also do this and have a few questions..
I need to buy my stainless lines for my car and my question is that I have a PMO regulator that has a return to the tank and am using Webers on my -6.. Should I be running all 4 lines from Tangerine or is there another better option?? I want this system safe.. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
a return line produces cooler fuel and should produce more HP (ever so slightly)
all modern cars use a return line and even the factory used a return line Attached image(s) ![]() |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
a return line produces cooler fuel and should produce more HP (ever so slightly) all modern cars use a return line and even the factory used a return line (IMG:http://www.914world.com/bbs2/uploads/post-47-1546535814.jpg) Option B won't work, in that case a reg needs to be on the return side of the circuit or it will never build pressure. BTDT I did D as well. |
Lo-Fi Version | Time is now: 16th June 2024 - 03:30 AM |
