5 lug drill template |
tmessenger |
Jan 2 2019, 04:52 PM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
This 914 came to me with 6x16 Fuchs wheels with the rears riding on 1" thick 5 bolt adapters. The prior reworked the rear fenders into some sort of mini flare for tire clearance.
The flares are not working for me so I have some body work to do. I bought a pair of 5 lug hubs to move the wheels in but need to fix the 4 lug brake disks. I figured I'd have a go at drilling them myself so made up a template in CAD. The attached pdf will print to scale on a 8-1/2 x 11" printer..... if you have the need. Tim 5_lug_temp.pdf ( 21.84k ) Number of downloads: 123 |
914Sixer |
Jan 2 2019, 08:32 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I can cut you some off parts car on trailer. Shipping is stupid though.
amfab |
Jan 3 2019, 06:25 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Deleted
TargaToy |
Jan 3 2019, 07:05 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
I did one as a narrow slot in the aluminum trim at the back of the Targa bar that worked well and was difficult to see when off. I don't have any photos with me. I can take a picture when I am back from vacation next week. Essentially it was an1/8th inch slot about seven inches long that I cut down the center of the trim with a cutoff tool that followed the slight curve of the targa bar trim. I then took an LED strip light and taped it inside the trim with aluminum tape and snapped the trim back on. I got one of those connector tab splitter things and ran a wire from the drivers taillight up the loom and out though the outer edge of the engine grill to up under the sail trim to get to the top trim. you can't see the wire from the outside if you get it far enough over. -Andrew Speaking of...third brake lights??? |
Lo-Fi Version | Time is now: 9th June 2024 - 02:51 PM |
