CV Joints, Available again? |
bbrock |
Oct 4 2018, 07:21 AM
I just plugged the OEM CV joint part # into Sunset Porsche's web site and got a hit ($73.64). So these are available again? (IMG:style_emoticons/default/confused24.gif)
https://www.sunsetporscheparts.com/oem-part...int-91433202903 EDIT: Don't Order these! What you get are 25-spline joints which appears to be the part for a 914-6. They won't fit on /4 axles. For more detail, see http://www.914world.com/bbs2/index.php?s=&...t&p=2698908 |
rgalla9146 |
Jan 4 2019, 03:57 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I just learned something interesting.
I have a 914 6 CV that's missing it's balls. (no rude comments please) So why not substitute some from a new modified Type 1 that I have on hand ? Cheap fix right ? Guess what ?.... the balls are bigger... and not in the direction that you'd guess. The balls in a VW CV are 17.44mm diameter. In the 914 6 they're 15.84 I'm no engineer but that doesn't seem right. You'll be comforted to know that 914 and 914 6 CVs have the same size balls. Attached thumbnail(s) |
mepstein |
Jan 4 2019, 07:10 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I just learned something interesting. I have a 914 6 CV that's missing it's balls. (no rude comments please) So why not substitute some from a new modified Type 1 that I have on hand ? Cheap fix right ? Guess what ?.... the balls are bigger... and not in the direction that you'd guess. The balls in a VW CV are 17.44mm diameter. In the 914 6 they're 15.84 I'm no engineer but that doesn't seem right. You'll be comforted to know that 914 and 914 6 CVs have the same size balls. I’m no bearing expert but smaller might mean more of them and thus more contact area on the race. At least it works that way with bikes. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:46 AM |
