Recirculation circuit for -6 with carbs.. |
mb911 |
Jan 2 2019, 01:36 PM
914 Guru Group: Members Posts: 6,901 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I know @MarkHenry has talked about this but I want to also do this and have a few questions..
I need to buy my stainless lines for my car and my question is that I have a PMO regulator that has a return to the tank and am using Webers on my -6.. Should I be running all 4 lines from Tangerine or is there another better option?? I want this system safe.. |
campbellcj |
Jan 5 2019, 08:22 AM
I can't Re Member Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have those PMO rails in a 'loop' configuration which years ago I speculated would help with distribution and cooling a bit and it has worked-out well. There is a small inline filter before the rails and a larger Canton canister-type filter closer to the pump up front. All the lines are AN-6 or hard metal.
IronHillRestorations |
Jan 5 2019, 01:17 PM
I. I. R. C. Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I have those PMO rails in a 'loop' configuration which years ago I speculated would help with distribution and cooling a bit and it has worked-out well. There is a small inline filter before the rails and a larger Canton canister-type filter closer to the pump up front. All the lines are AN-6 or hard metal. Wait a minute! You have way to many spark plug wires!! What the.... (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 06:30 AM |
