5 lug drill template |
tmessenger |
Jan 2 2019, 04:52 PM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
This 914 came to me with 6x16 Fuchs wheels with the rears riding on 1" thick 5 bolt adapters. The prior reworked the rear fenders into some sort of mini flare for tire clearance.
The flares are not working for me so I have some body work to do. I bought a pair of 5 lug hubs to move the wheels in but need to fix the 4 lug brake disks. I figured I'd have a go at drilling them myself so made up a template in CAD. The attached pdf will print to scale on a 8-1/2 x 11" printer..... if you have the need. Tim 5_lug_temp.pdf ( 21.84k ) Number of downloads: 124 |
tmessenger |
Jan 3 2019, 07:39 PM
I worked on one side today and got it back about 75% with various hammers and dollies. I'm now going to split it vertically in the center so that stretched metal has a place to go then I can trim out the excess and weld it back. I'll post a pic when I make more progress.
Tim This 914 came to me with 6x16 Fuchs wheels with the rears riding on 1" thick 5 bolt adapters. The prior reworked the rear fenders into some sort of mini flare for tire clearance. The flares are not working for me so I have some body work to do. I bought a pair of 5 lug hubs to move the wheels in but need to fix the 4 lug brake disks. I figured I'd have a go at drilling them myself so made up a template in CAD. The attached pdf will print to scale on a 8-1/2 x 11" printer..... if you have the need. Tim 5_lug_temp.pdf ( 21.84k ) Number of downloads: 124 |
tmessenger |
Jan 7 2019, 04:52 PM
Close enough for bondo. Also the rear brake disc are fairly easy to drill.
Tim [quote name='tmessenger' date='Jan 3 2019, 07:39 PM' post='2678629'] I worked on one side today and got it back about 75% with various hammers and dollies. I'm now going to split it vertically in the center so that stretched metal has a place to go then I can trim out the excess and weld it back. I'll post a pic when I make more progress. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:30 PM |
