Machining tolerances for boring out Mahle cylinders to 96mm |
seanpaulmc |
Jan 7 2019, 08:21 PM
Member Group: Members Posts: 304 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Looking to get a set of original 94mm Mahle 2.0L cylinders bored out to 96mm. What are the recommended tolerances for giving to the machine shop for this diameter?
Thank you, Sean |
wndsrfr |
Jan 8 2019, 07:03 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Looking to get a set of original 94mm Mahle 2.0L cylinders bored out to 96mm. What are the recommended tolerances for giving to the machine shop for this diameter? Thank you, Sean You'll need to give them your new set of pistons so they can do it right...usually the new pistons come with an info sheet for tolerances... |
mepstein |
Jan 8 2019, 08:09 AM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Looking to get a set of original 94mm Mahle 2.0L cylinders bored out to 96mm. What are the recommended tolerances for giving to the machine shop for this diameter? Thank you, Sean You'll need to give them your new set of pistons so they can do it right...usually the new pistons come with an info sheet for tolerances... (IMG:style_emoticons/default/agree.gif) We do a lot of 3.2 to 3.4. the cylinders should have a spec sheet. I think they charge us $75 a jug. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:53 AM |
