| mepstein |
Jul 25 2015, 11:28 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,923 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Parts acquisition
| Amenson |
Jan 9 2019, 09:40 PM
That's opposite lock!! ![]() ![]() ![]() Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None
Had an interesting discussion going so I moved it to the proper place...
Scott the flip is not hard, some of the stuff just needs to moved to make it happen, like we talked about. Once you see the EG you will know. The IRIS system is what clutters up the flip. I don't think You're going to have an issue with it. It is very easy if Mark is not going to have AC in the car, becomes harder if Mark is. Workshop is looking great, let me know if there is anything you need from me to help these along. (IMG:style_emoticons/default/poke.gif) Yeah I know of 5 little round items you need all ready (IMG:style_emoticons/default/huh.gif) I don’t want to turn this into a thread for my car but...I do want a/c & heat. I was hoping the bulkhead mount might make things a bit easier with positioning but that might not be the case. My plan is not to micromanage the build but to turn it over to Scott A and let him do his thing. The only challenge I see with the build is Scott likes to build to a high standard for both looks and functionality and I’m looking for a good running conversion but not a showcase car. I’m sure it will work out. The nice thing is with my car is there is no fresh paint to worry about. (IMG:style_emoticons/default/lol-2.gif) Fresh paint, and yes this is about PorSTI, we just started talking about EG33 intake flips. I am a huge proponent that the bulkhead mounts for the EG, if anything it allows for even better positioning of the engine giving the clearance needed for the flip. Mark I am sure a build thread will be started to discuss your car, once the process starts. Oh, don't worry your car will be built to a high standard for looks and functionality...efficiently. Getting the engine sitting properly in the available space is key. Ditching the cradle will help a lot and I think that we should consider a shortened oil pan. Lowering the engine should open up enough space to flip the manifold so that we can shift the engine back and get the axles straight (and use an electric motor AC compressor maybe) or leave it as is keep AC either way keeping the trunk uncut. It would be a shame to hack it up after spending the time to install the the donor trunk section. PorSTi has a shortened pan from Outfront but I am not sure if they do one for the EG. If not small car has a nice cast aluminum EG pan. Tom wants heat on Grey also so I added connections to the radiator lines for it. I have concept for a heater but Grey doesn't have all of the air diverters and stuff installed for mock-up and quite frankly I need to end scope creep on the project so so that Tom can have it back in time to have the opportunity to do final assembly before spring. We can develop it on your car. |
mepstein Porsche 914/Subaru svx build Jul 25 2015, 11:28 AM
mepstein Harness - brain surgery
Big thanks to Kevin today... Jul 25 2015, 11:34 AM
mepstein My mechanic pulled the engine Jul 25 2015, 11:40 AM
mepstein Next step is remove the roll cage and get it up on... Jul 25 2015, 11:44 AM
Mueller Nice....now to stop reading your threads....I don... Jul 25 2015, 11:48 AM
Nice....now to stop reading your threads....I don... Jul 25 2015, 11:53 AM
Chris H. Nice work pulling the harness complete. Are you d... Jul 25 2015, 12:13 PM
Nice work pulling the harness complete. Are you ... Jul 25 2015, 12:22 PM
Chris H. Oh you picked up the smallcar directions? :idea:... Jul 25 2015, 06:05 PM
914forme :headbanger: Lets get to rocking, Im guessing we c... Jul 25 2015, 06:06 PM
:headbanger: Lets get to rocking, Im guessing we ... Jul 25 2015, 09:11 PM
914forme Wow Chris those videos make me glad I'm doing ... Jul 25 2015, 06:09 PM
Chris H. Yeah the first vid is a bit cheesy but it explains... Jul 25 2015, 06:14 PM
Andyrew Awesome!! Jul 25 2015, 06:16 PM
mepstein Since I have these trailing arms I'm guessing ... Jul 26 2015, 09:11 AM
mepstein T struts and M calipers. Not pretty but functional... Jul 26 2015, 09:45 AM
mepstein Using 911 e brake so I bought these from tangerine... Aug 6 2015, 03:19 PM
mepstein So I need a trans. Can anyone help me find the rig... Aug 27 2015, 07:44 PM
76-914
So I need a trans. Can anyone help me find the ri... Aug 28 2015, 08:52 AM
So I need a trans. Can anyone help me find the r... Aug 28 2015, 11:43 AM
Cairo94507 Mark - How do you keep track of which car you are ... Aug 28 2015, 10:09 AM
Mark - How do you keep track of which car you are... Aug 28 2015, 11:41 AM
mepstein Zach found me a trans. Picked it up last night. Th... Sep 16 2015, 06:32 AM
mepstein A little controversy, or not. Sep 16 2015, 02:54 PM
strawman I'm using the transaxle out of a U.S. 1998 For... Sep 17 2015, 11:32 AM
nsyr I have had a fwd subaru trans in my now svx powere... Sep 17 2015, 01:57 PM
mepstein more stuff Sep 24 2015, 08:45 PM
mepstein Back on the suby build
I sent out the wire harness... Jun 25 2016, 07:46 PM
76-914 I don't know why you'd "farm out... Jun 26 2016, 09:29 AM
mepstein If I didn't farm it out, it wouldn't get d... Jun 26 2016, 01:33 PM
flmont Whom,..May I asked did u send it out too,..smallca... Jun 27 2016, 08:31 PM
Whom,..May I asked did u send it out too,..smallc... Jun 27 2016, 09:17 PM
mepstein Here's the harness all done and ready to ship.... Jul 10 2016, 04:30 PM
flmont Who did your harness,..?? if I may ask Jul 11 2016, 05:34 PM
flmont Sorry,..I just scrolled up,..Jezz.. Thanks Jul 11 2016, 05:35 PM
flmont Sorry,..I just scrolled up,..Jezz.. Thanks Jul 11 2016, 06:20 PM
mepstein I don't want to be known as the guy to where 9... Jan 4 2017, 09:14 PM
76-914 That harness looks nice. Who and where is the car ... Jan 5 2017, 10:13 AM
That harness looks nice. Who and where is the car... Jan 5 2017, 10:33 AM
76-914
That harness looks nice. Who and where is the ca... Jan 5 2017, 05:46 PM
914forme
[quote name='mepstein' post='2441025' date='Jan 5... Jan 5 2017, 08:27 PM
76-914
[quote name='mepstein' post='2441025' date='Jan ... Jan 5 2017, 09:09 PM
914forme
[quote name='914forme' post='2441174' date='Jan 5... Jan 5 2017, 10:18 PM
76-914
[quote name='914forme' post='2441174' date='Jan ... Jan 6 2017, 08:54 AM
mgp4591
[quote name='mepstein' post='2441025' date='Jan 5... Jan 6 2017, 02:05 PM
914forme Glad to see this one getting finished up this spri... Jan 5 2017, 05:37 PM
flmont Mines not completed yet,..But I do have all major ... Jan 5 2017, 06:40 PM
mepstein I still need a radiator and fuel pump but I'll... Jan 5 2017, 06:57 PM
914forme
I still need a radiator and fuel pump but I'l... Jan 5 2017, 08:29 PM
76-914
I still need a radiator and fuel pump but I'l... Jan 5 2017, 09:11 PM
jmill
Then make it pretty with a hardtop and a/c.
Ste... Jan 6 2017, 04:09 PM
914forme
St... Jan 6 2017, 05:46 PM
Andyrew
[quote name='jmill' post='2441374' date='Jan 6 20... Jan 31 2017, 04:37 PM
mepstein I need to put this on wheels to get to the builder... Jan 31 2017, 03:52 PM
mepstein I got tired of looking at the roll cage.
Step 1 -... Feb 2 2017, 04:03 PM
mepstein Step 2
:sawzall: Feb 2 2017, 04:04 PM
914forme Mark you also sending brake parts, the builder lik... Feb 2 2017, 07:11 PM
Mark you also sending brake parts, the builder li... Feb 2 2017, 07:27 PM
914forme ?
I don't think I bought your calipers :conf... Feb 2 2017, 09:41 PM
I don't think I bought your calipers :con... Feb 2 2017, 10:00 PM
914forme
I don't think I bought your calipers :co... Feb 3 2017, 03:26 PM
Amenson
[quote name='mepstein' post='2450706' date='Feb 2... Feb 3 2017, 03:40 PM
914forme
[quote name='mepstein' post='2450706' date='Feb ... Feb 3 2017, 04:27 PM
[quote name='Amenson' post='2450921' date='Feb 3 ... Feb 3 2017, 09:51 PM
mepstein I ground down the stumps from the roll cage. Doesn... Mar 20 2017, 03:13 PM
76-914 Uh, I hate to ask but is that a rust sensor screwe... Mar 20 2017, 03:18 PM
Andyrew Looks like a seat belt bolt Mar 20 2017, 03:41 PM
mepstein Just the seat belt bolt and a wire. :D Mar 20 2017, 03:41 PM
Had an interesting discussion going so I moved it... Jan 9 2019, 09:51 PM
jimkelly mark, looks like me and you, or you and i, may hav... Jan 10 2019, 09:20 PM
mark, looks like me and you, or you and i, may ha... Jan 10 2019, 10:02 PM
KELTY360 Unfortunately, the EG33 in my Syncro Westy took a ... Jan 11 2019, 12:00 AM
Amenson
Unfortunately, the EG33 in my Syncro Westy took a... Jan 11 2019, 04:48 PM
914forme Scott I have one in the shop if you want me to mea... Jan 19 2019, 01:33 PM
914forme While in the shop I dug out my Smaller oil pan, ha... Jan 19 2019, 11:02 PM
tazz9924
While in the shop I dug out my Smaller oil pan, h... Jan 20 2019, 08:49 AM
mepstein I didn't think a shallow oil pan was needed on... Jan 20 2019, 08:44 AM
Amenson Stephen,
Thanks for the measurements and pictures.... Jan 20 2019, 02:22 PM
mepstein Sold the coldwater cradle a while ago.
Here's ... Jan 20 2019, 08:51 AM
JRust
Here's... Jan 20 2019, 06:52 PM
Here... Jan 20 2019, 07:48 PM
914forme :agree: 100%
Mine is dropped and saves all the tr... Jan 20 2019, 02:38 PM
:agree: 100%
Mine is dropped and saves all the t... Jan 20 2019, 02:50 PM
KELTY360 Mark, Stephan and Scott - I haven't gone MIA, ... Jan 20 2019, 03:55 PM
Mark, Stephan and Scott - I haven't gone MIA,... Jan 20 2019, 04:10 PM
914forme
Mark, Stephan and Scott - I haven't gone MIA,... Jan 20 2019, 06:23 PM
mepstein Only took 4 years to get suspension on the car. Sep 7 2019, 12:33 PM
76-914 Don't rush it! :D Sep 7 2019, 01:59 PM
914forme :Qarl: Hoping that means what I think it means :Q... Sep 7 2019, 07:42 PM
:Qarl: Hoping that means what I think it means :... Sep 7 2019, 08:16 PM
mepstein I purchased as a bare chassis so I’m happy to fi... Sep 9 2019, 10:36 AM
mepstein Loaded up and on it’s way to Scott Amerson to ge... Feb 8 2020, 07:50 PM
914forme Can not wait too see this unfold. :popcorn: Look... Feb 8 2020, 08:30 PM
Amenson That is a nice trailer...does it stay with the pro... Feb 8 2020, 09:53 PM
76-914 So you're going Turbo? Feb 8 2020, 10:12 PM
Tdskip Oh man, I had no idea this was underway. Nice mome... Feb 8 2020, 11:57 PM
Cairo94507 Congratulations Mark :trophy: . That is a major ... Feb 9 2020, 02:46 PM
76-914 Once you go Subaru you never go back! >:D Feb 9 2020, 08:50 PM
Amenson The stars aligned and the EG has landed. Unfortun... Feb 9 2020, 09:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd October 2026 - 08:02 PM |
