Does anyone rebuild AARs professionally? |
Tdskip |
Jan 11 2019, 10:18 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I’m starting to think the 731.7 FI car has a wonky AAR, still need to do more testing to make sure, but that led me to wonder if anyone rebuilds these professionally for us?
Sorry if this is common knowledge and I just haven’t caught up with y’all yet. |
Dave_Darling |
Jan 11 2019, 12:45 PM
They are not that hard to repair at home, though. The can part crimps over the lid that holds the pipes. The metal of the can is a bit thick, but it can definitely be pried back. You can then pull the top, containing the moving bits, out of the can. Lubricate it and work it a bit and it should free up.
If the resistance wire in the base of the can is broken, that's a little more involved. You can replace it with a 1-watt ~15-ohm resistor, if you can find one that fits in the space available. One end of the resistor would be attached to the can itself, the other would be attached to a wire that comes through the can, but is insulated from the can. If the bimetallic spring is broken, or if you cannot free up the rotary valve, then replace the whole thing. --DD |
Lo-Fi Version | Time is now: 16th June 2024 - 05:57 PM |
