MSDS exhaust headers; 914-6 / 914-4, 914 World member discounts from Maltese Falcon |
Maltese Falcon |
Oct 24 2015, 05:35 PM
Advanced Member Group: Members Posts: 4,701 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
MSDS street/ track proven long tube exhaust headers are now being offered to 914 World forum members at 10% discount. This is not a monthly special...it is offered year round (IMG:style_emoticons/default/smile.gif)
All of our products are hand crafted in house, here in our Glendale California plant (IMG:style_emoticons/default/flag.gif) Check out all of our 914-6 and 914-4 exhaust headers at Www.msdsinc.com Contact via PM Tech@msdsinc.com 818.507.6937 |
audio_file |
Mar 27 2017, 11:30 AM
Member Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest |
When using these beautiful /4 headers, how are you guys supporting the weight of the exhaust? I'm assuming the boomerang bar won't work for the new system?
Maltese Falcon |
May 23 2017, 04:04 PM
When using these beautiful /4 headers, how are you guys supporting the weight of the exhaust? I'm assuming the boomerang bar won't work for the new system? Best method for supporting the custom fit muffler is to simply extend a small bracket from muffler-to-tailhousing on the transaxle. You can use both (or one) of the existing 8 x1.25mm short studs which are the same support locating points as the OE bracket. Use 1 x .125 " (min) flatbar steel. |
7TPorsh |
Jun 1 2017, 12:29 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
When using these beautiful /4 headers, how are you guys supporting the weight of the exhaust? I'm assuming the boomerang bar won't work for the new system? Best method for supporting the custom fit muffler is to simply extend a small bracket from muffler-to-tailhousing on the transaxle. You can use both (or one) of the existing 8 x1.25mm short studs which are the same support locating points as the OE bracket. Use 1 x .125 " (min) flatbar steel. Yep, that's how it's done. Bolted on bracket to pipe |
bgegel |
Jan 11 2019, 03:11 PM
Newbie Group: Members Posts: 6 Joined: 10-June 18 From: San Antonio Member No.: 22,210 Region Association: Southwest Region |
What type of muffler do you recommend with you headers on a 914-4? Do you have any pictures? Thanks. --- Brian
Lo-Fi Version | Time is now: 10th June 2024 - 12:44 PM |
