> Rust cover up?, Car looks good, but how can I tell if rust is just covered
Jon199
post Jan 12 2019, 07:25 AM
I am considering purchasing this project 914. I am concerned that rust may have been covered up by a rhino lining or similar spray application at the hell hole. Does anyone have any knowledge of the car or any advice as to what exactly what I should be looking for when I go inspect the car in person?
Thanks,
JonAttached Image Attached ImageAttached ImageAttached Image[attachmentid=682
144]Attached Image
Jon199
post Jan 13 2019, 04:05 PM
Thank you everyone for your opinions and advice. My first Porsche was a 993. I loved the car, but did not like how the ass end would get light if you let off the gas in a corner. I would like to get a mid engine Porsche this time around. I like the idea of a light 914, but I want to have enough power to give that pushed back into the seat feeling. Also, I want something I can drive to the track for drivers education a few times a year. So I should probably be looking for a cayman. Any thoughts?
Thanks,
Jon
Superhawk996
post Jan 14 2019, 06:30 PM
QUOTE(Jon199 @ Jan 13 2019, 05:05 PM) *
Thanks,
Jon
Jon, there is a fine line between a car that is neutral in a corner and one that gets light tending toward classic oversteer (i.e. 911's). Frankly that line is based on personal opinion and driving style.
The secret is don't lift in the corner. If you have your speed set at corner entry, you really want to be easing back into the throttle during the corner rather than lifting which is panic reaction to having gone in too fast. This transfers weight to the rear axle and helps stabilize that rear end.
However, you are on the right track. Do as much driver education and track time as you can afford and find time for. You won't regret it. A Cayman is a fine car but being that it is a Porsche you'll find that it too will be neutral to oversteering on an abrupt lift throttle. You can't go wrong with a Cayman but don't expect it to be forgiving of an abrupt lift during a corner either.
If you're not already aware, the main issue with 914 handling (and a mid-engine Cayman) is that once you start to lose it, the car can rotate pretty fast due to low polar moment of inertia that is why we love mid-engine handling in the first place.
Good luck in your quest.
VaccaRabite
post Jan 15 2019, 09:01 AM
En Garde!
QUOTE(Superhawk996 @ Jan 14 2019, 07:30 PM) *
Couple points here.
My 914 (which is a mild 2056 making about 150 at the crank on the dyno) will push you into your seat WOT in 2nd and 3rd. A 914 tends to be a quick car, but not a fast car. My stock WRX is faster and feels faster in nearly every regard. In stock or near stock forms, they will never match a modern Porsche in terms of speed. They will struggle with some mini-vans in a drag race. They are 40+ year old cars, and even when new they were not speed demons. They were always cornering cars, and to this day they can out corner almost anything on the road.
I've been in a stock 2L spinning, and it happens very very fast with little time to correct. I've also been in a stock 2L where I looked at the other guy after a corner where the car held the line even when we were both puckering. The best way to deal with it is just seat time, learning how your car reacts and teaching yourself NOT to panic stop mid corner, but rather to slow down before the corner and throttle through it.
Zach
Jon199   Rust cover up?   Jan 12 2019, 07:25 AM
dlee6204   I can tell from the pictures that there was a very...   Jan 12 2019, 07:40 AM
Jon199   That’s what I was afraid of.   Jan 12 2019, 07:58 AM
Superhawk996   :chair: The carnage occurring to 914's is atr...   Jan 12 2019, 08:14 AM
Superhawk996   Oh, the two best things to bring with you on a pot...   Jan 12 2019, 08:21 AM
Jon199   Superhawk, Thank you for the advice and the educat...   Jan 12 2019, 08:58 AM
Superhawk996   Superhawk, Thank you for the advice and the educa...   Jan 12 2019, 09:29 AM
Tdskip   Welcome Jon! As you have seen already it is a...   Jan 12 2019, 09:08 AM
Tbrown4x4   Those pictures show so many substandard repairs...   Jan 12 2019, 09:55 AM
jmitro   I disagree with some of the assessments above. tho...   Jan 12 2019, 10:01 AM
SirAndy   I disagree with some of the assessments above. tho...   Jan 13 2019, 12:19 AM
rhodyguy   Why does everything on the bottom or the car seem ...   Jan 12 2019, 10:02 AM
Jonathan Livesay   Why does everything on the bottom or the car seem...   Jan 12 2019, 11:29 AM
IronHillRestorations   This car looks like someone else's problems to...   Jan 12 2019, 10:16 AM
bbrock   :agree: with everything said above. I don't t...   Jan 12 2019, 10:20 AM
TravisNeff   That exhaust is very low, careful on speed bumps...   Jan 12 2019, 10:39 AM
76-914   Run Forest, run. I have two H20 conversions and on...   Jan 12 2019, 11:19 AM
rhodyguy   What's the asking price on this car?   Jan 12 2019, 11:25 AM
dr914@autoatlanta.com   HORRIBLE   Jan 12 2019, 11:33 AM
Mike Bellis   Motor hangs too low. Motor mounts look wonky. Copp...   Jan 12 2019, 12:09 PM
mepstein   craigslist maine $10,500 https://nh.craigsli...   Jan 12 2019, 12:21 PM
Jonathan Livesay   craigslist maine $10,500 https://nh.craigsl...   Jan 12 2019, 09:30 PM
tomh   Buy the most car you can afford and have fun with ...   Jan 12 2019, 12:25 PM
amfab   If you go out to look at it, use the factory jack ...   Jan 12 2019, 03:22 PM
John   That's a lot to ask for a cheaply done 914 con...   Jan 13 2019, 12:53 AM
Jon199   Thank you everyone for your opinions and advice. ...   Jan 13 2019, 04:05 PM
Superhawk996   Thank you everyone for your opinions and advice. ...   Jan 14 2019, 06:30 PM
amfab   My 993 is much more forgiving than earlier 911s it...   Jan 14 2019, 09:15 PM
VaccaRabite   Thank you everyone for your opinions and advice....   Jan 15 2019, 09:01 AM
mepstein   If you want a car that can do it all, in comfort a...   Jan 13 2019, 04:49 PM
jmitro   i agree with superhawk996 comments about tracking....   Jan 14 2019, 09:56 PM
914 Ranch   If you're going to buy it to have a hot rod co...   Jan 14 2019, 10:57 PM
burton73   Dude, A Boxster or Cayman if you can afford one i...   Jan 15 2019, 04:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:19 AM
