> Clutch adjustment instructions, from the 31 pages
Dr Evil
post Jun 13 2012, 01:47 PM
Send me your transmission!
From my 31 pages of trans notes:
*Clutch cable
The clutch cable being too loose is probably one of the most common reasons that people’s shifting sucks. If your cable is too loose then you will not be able to fully disengage the pressure plate from the clutch disk and you will keep power to the transmission. If it is really loose then reverse will grind when shifting into it from a standstill. There is no way that this should happen if the clutch is fully disengaged. To properly adjust your clutch, you need to tighten the cable until the clutch disengages at about 1/4 to 1/3 pedal travel (See figure 1 in appendix). If the clutch disengages too early then it is too tight, too late then it is too loose.
MikeM
post Jan 15 2019, 10:48 AM
Hi all...don't mean to hijack...
My clutch pedal feels light and springy. I checked the cable tube and it's very solid.
Now what?
Shifts OK, but clutch feels weird.
Mike
Bartlett 914
post Jan 15 2019, 02:24 PM
QUOTE(MikeM @ Jan 15 2019, 10:48 AM) *
Now what?
Mike
Where and how did you check the clutch tube? It may be tight at the rear but loose near the front of the tube which it usually breaks free first. Later it breaks free in the middle then at the firewall. Another issue is with the accelerator cable. If installed improperly, it can be wrapped around the clutch cable causing issues
Dr Evil   Clutch adjustment instructions   Jun 13 2012, 01:47 PM
Dr Evil   If your clutch cable seems impossible to adjust, y...   Jun 13 2012, 01:50 PM
Dr Evil   Also, it is often that the replacement cable is to...   Jun 13 2012, 01:51 PM
buck toenges   Also, it is often that the replacement cable is t...   Jan 14 2019, 03:47 PM
jim_hoyland   I was under the impression that the clutch should ...   Jun 13 2012, 01:53 PM
Dr Evil   I was under the impression that the clutch should...   Jun 13 2012, 02:09 PM
shoguneagle   Good job, Doc. I do everything the Doc has said b...   Jun 13 2012, 02:02 PM
jim_hoyland   So I need to tighten a little bit more so that the...   Jun 13 2012, 04:27 PM
Dr Evil   The floor stop is there to make sure you do not ov...   Jun 13 2012, 04:52 PM
tomrev   The floor stop is there to make sure you do not o...   May 20 2014, 03:04 PM
ClayPerrine   Just an addendum to the evil doctor's commenta...   May 20 2014, 03:13 PM
tomrev   Just an addendum to the evil doctor's comment...   May 20 2014, 04:36 PM
JawjaPorsche   Most people use aluminum tubing and have seen peop...   Jan 14 2019, 06:56 PM
Dave_Darling   One thing to note: The "helper" spring ...   Jan 14 2019, 10:44 PM
MikeM   Hi all...don't mean to hijack... My clutch ped...   Jan 15 2019, 10:48 AM
Bartlett 914   Hi all...don't mean to hijack... My clutch pe...   Jan 15 2019, 02:24 PM
MikeM   I removed the console, carpet and shifter. Tube in...   Jan 15 2019, 04:58 PM
Bartlett 914   I removed the console, carpet and shifter. Tube i...   Jan 15 2019, 05:17 PM
second wind   From my 31 pages of trans notes: *Clutch cable ...   Jan 15 2019, 11:11 PM
porschetub   From my 31 pages of trans notes: *Clutch cable ...   Jul 13 2022, 07:44 PM
- Lo-Fi Version Time is now: 5th November 2026 - 03:00 AM
