Parts Check: 2.0 L Cold Start Valve, Anybody Want One |
914Sixer |
Jan 15 2019, 03:40 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I found a source for some NOS 2.0L cold start valve. They will be reasonably priced at around $120 shipped, not the $200+ prices on Ebay. I will take about a month to get them because of the location. Let me know if you want one. Going to order at the first of next week.
Attached image(s) |
JeffBowlsby |
Jan 15 2019, 07:47 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Unless you live in a location at or below freezing, the thermoswitch/TTS (temp driven ground for the CSV electrical circuit) will not activate and the CSV is never called into service to provide fuel. They become a problem when it leaks though (too rich) even in warm climates. Suggest that these are only needed by the cold climate folks and everyone else should just delete or disconnect them.
TS/TTS values (from Anders): 311 906 161 : -12 to -18 deg. C / 10 to 0 deg. F 311 906 161 A : 0 to -10 deg. C / 32 to 14 deg. F 311 906 161 B : -2 to -8 deg. C / 28 to 18 deg. F 311 906 161 C : -6 to -14 deg. C / 21 to 7 deg. F |
nditiz1 |
Jan 16 2019, 12:47 PM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Unless you live in a location at or below freezing, the thermoswitch/TTS (temp driven ground for the CSV electrical circuit) will not activate and the CSV is never called into service to provide fuel. They become a problem when it leaks though (too rich) even in warm climates. Suggest that these are only needed by the cold climate folks and everyone else should just delete or disconnect them. TS/TTS values (from Anders): 311 906 161 : -12 to -18 deg. C / 10 to 0 deg. F 311 906 161 A : 0 to -10 deg. C / 32 to 14 deg. F 311 906 161 B : -2 to -8 deg. C / 28 to 18 deg. F 311 906 161 C : -6 to -14 deg. C / 21 to 7 deg. F Fully agree on this. In MD temps do get to freezing and below during 3 months out of the year. I have started my car below freezing temps and while it initially starts with a low idle it quickly raises to above 1500 RPMs as part of the normal startup of FI. As Jeff stated the less items that can cause problems in the FI the better. I believe another member on here as well as others have removed the CSV, decel Val, and there was one more. My car currently has a disabled CSV and no Decel Val. It starts and runs great without these. |
BeatNavy |
Jan 16 2019, 01:45 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
My car currently has a disabled CSV and no Decel Val. It starts and runs great without these. Careful, Nick, you can blow out your MPS without that decal valve in place (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 09:01 PM |
