Gas tank threaded fittings size? |
mb911 |
Jan 15 2019, 07:48 PM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I need to chase the threads on my tank where the fuel lines connect.. Anyone know off the top of your head? Need to order a die for it.
Bartlett 914 |
Jan 17 2019, 10:29 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I like the idea of using a 1/4 pipe nipple. You will need to ream out the hole to 7/16" for proper threading. I have wanted to install a drain valve and using 1/4 piping will make this easy. Twice now I have purchased bad gas (water in the gas) while some distance from home. This would make it fast and easy to drain out any water that may have settled to the bottom of the tank.
Lo-Fi Version | Time is now: 9th June 2024 - 11:59 PM |
