> V8 conversion - clutch problem
DickSteinkamp
post Jan 17 2019, 02:52 PM
1988 SBC, KEP 9" flywheel, 228mm HP pressure plate, 228mm kevlar faced disc. TOB from Renegade matched to the KEP parts.
The clutch will disengage, but only very close to the bottom of the pedal travel. In fact, I had to remove the pedal stop. There is almost no free play in the pedal at this point. If I add more free play, the clutch will not disengage.
I understand the "fix" for this is to space the pivot ball towards the clutch. Is there any way to determine how thick of a washer to use? I'd dearly love to do this once. (IMG:style_emoticons/default/smile.gif)
DickSteinkamp
post Jan 17 2019, 05:00 PM
No movement of clutch tube in tunnel.
Not sure what you mean by "at the fork". There is about 1/4" free play at the pedal (pulling it up from its resting place).
I understand this is also a common problem on a stock car when the flywheel is surfaced. Generally a shim is added under the fork pivot ball equal to the amount taken off the flywheel.
DickSteinkamp   V8 conversion - clutch problem   Jan 17 2019, 02:52 PM
djway   Have you checked to see if there is any movement o...   Jan 17 2019, 04:38 PM
Chi-town   Also how much free play is there at the fork?   Jan 17 2019, 04:52 PM
DickSteinkamp   No movement of clutch tube in tunnel. Not sure wh...   Jan 17 2019, 05:00 PM
Chris914n6   tighten the cable until it releases where you want...   Jan 17 2019, 06:00 PM
DickSteinkamp   tighten the cable until it releases where you wan...   Jan 17 2019, 06:12 PM
Chi-town   I meant can you wiggle the release fork with the c...   Jan 17 2019, 07:56 PM
djway   I have seen that with a broken or dislodged TO bea...   Jan 17 2019, 09:29 PM
DickSteinkamp   I have seen that with a broken or dislodged TO be...   Jan 17 2019, 09:37 PM
sixnotfour   plastic pivot bushing in throw out arm ??   Jan 17 2019, 09:38 PM
DickSteinkamp   plastic pivot bushing in throw out arm ?? Yes....   Jan 17 2019, 09:53 PM
djway   Once TO contacts plate there should only be about ...   Jan 18 2019, 02:32 AM
DickSteinkamp   I poked around this morning and learned a few thin...   Jan 18 2019, 03:54 PM
djway   I poked around this morning and learned a few thi...   Jan 18 2019, 09:45 PM
Mike Bellis   Do all your research and then put a washer under t...   Jan 18 2019, 07:38 PM
DickSteinkamp   Do all your research and then put a washer under ...   Jan 18 2019, 08:33 PM
Mike Bellis   Thanks, Mike. The car is down for paint and the...   Jan 19 2019, 12:32 AM
DickSteinkamp   Lots of smart people in this forum so you will le...   Jan 19 2019, 09:24 AM
shoguneagle   Got interested in your problems; currently convert...   Mar 11 2019, 01:48 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:29 AM
