| DickSteinkamp |
Jan 17 2019, 02:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
1988 SBC, KEP 9" flywheel, 228mm HP pressure plate, 228mm kevlar faced disc. TOB from Renegade matched to the KEP parts.
The clutch will disengage, but only very close to the bottom of the pedal travel. In fact, I had to remove the pedal stop. There is almost no free play in the pedal at this point. If I add more free play, the clutch will not disengage. I understand the "fix" for this is to space the pivot ball towards the clutch. Is there any way to determine how thick of a washer to use? I'd dearly love to do this once. (IMG:style_emoticons/default/smile.gif) |
| Chi-town |
Jan 17 2019, 07:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
I meant can you wiggle the release fork with the current cable adjustment?
You can adjust the cable till the TO bearing is just very slightly putting pressure but anymore will cause premature bearing issues. I would call Kennedy and see what they say. |
DickSteinkamp V8 conversion - clutch problem Jan 17 2019, 02:52 PM
djway Have you checked to see if there is any movement o... Jan 17 2019, 04:38 PM
Chi-town Also how much free play is there at the fork? Jan 17 2019, 04:52 PM
DickSteinkamp No movement of clutch tube in tunnel.
Not sure wh... Jan 17 2019, 05:00 PM
Chris914n6 tighten the cable until it releases where you want... Jan 17 2019, 06:00 PM
DickSteinkamp
tighten the cable until it releases where you wan... Jan 17 2019, 06:12 PM
djway I have seen that with a broken or dislodged TO bea... Jan 17 2019, 09:29 PM
DickSteinkamp
I have seen that with a broken or dislodged TO be... Jan 17 2019, 09:37 PM
sixnotfour plastic pivot bushing in throw out arm ?? Jan 17 2019, 09:38 PM
DickSteinkamp
Yes.... Jan 17 2019, 09:53 PM
djway Once TO contacts plate there should only be about ... Jan 18 2019, 02:32 AM
DickSteinkamp I poked around this morning and learned a few thin... Jan 18 2019, 03:54 PM
djway
I poked around this morning and learned a few thi... Jan 18 2019, 09:45 PM
Mike Bellis Do all your research and then put a washer under t... Jan 18 2019, 07:38 PM
DickSteinkamp
Do all your research and then put a washer under ... Jan 18 2019, 08:33 PM
Mike Bellis
Thanks, Mike.
The car is down for paint and the... Jan 19 2019, 12:32 AM
DickSteinkamp
Lots of smart people in this forum so you will le... Jan 19 2019, 09:24 AM
shoguneagle Got interested in your problems; currently convert... Mar 11 2019, 01:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:06 PM |
