> V8 conversion, is it possible to keep the original front bumper completely intact? ie Not cut holes in it.
billium01
post Jan 24 2019, 07:47 PM
Hello,
water cooled 914 here. I have an LS6 motor I'm dropping in. Has anyone ducted a radiator successfully without cutting the front bumper? I'd like to keep the bumper intact and use a front lower valance for an intake. Was going to lay the radiator in the front trunk at an angle. Thanks!
Bill
Chi-town
post Jan 26 2019, 02:24 PM
You're the first person I've seen that says LS's run hot.
Once you get away from the standard 195 degree + emissions set up it's actually quite easy to keep them cool.
The idea I was kicking around was cutting a hole into the floor similar to what the A/C kits do and then ducting through the hood
Andyrew
post Jan 27 2019, 03:01 PM
Spooling.... Please wait
QUOTE(Chi-town @ Jan 26 2019, 12:24 PM) *
My point was they typically run at 215+ but I see your point. I'm sure they are easier to keep cool than a typical SBC. But no front cutout is extremely unlikely to keep cool... There is a damn good reason the rennegade cooling system is the way it is.
I would hate to push/pull air from the ground. If you pulled air it would be really hot on a hot summer day and would probably overheat due to the super high ambient temperature of the asphalt at low speeds/idling. And if you pushed air through it then you would just dust the area around you as well as create front end lift at higher speeds.
billium01   V8 conversion, is it possible to keep the original front bumper completely intact? ie Not cut holes in it.   Jan 24 2019, 07:47 PM
Coondog   Running a 3.2, with a uncut bumper and a custom cu...   Jan 24 2019, 08:04 PM
amfab   Well done valence modification!   Jan 24 2019, 10:09 PM
djway   I have heard of some LS1 swaps without bumper cut ...   Jan 25 2019, 12:23 AM
billium01   Thanks for the ideas and info guys. I think the fr...   Jan 25 2019, 11:05 AM
Chris H.   Yes the Renegade Hybrids valance is nice. It...   Jan 25 2019, 11:33 AM
Chris914n6   I use the pre-cut holes behind the valance and the...   Jan 25 2019, 01:12 PM
Andyrew   LS motors run pretty hot. I don't think you...   Jan 25 2019, 01:25 PM
Chi-town   You're the first person I've seen that say...   Jan 26 2019, 02:24 PM
djway   You're the first person I've seen that sa...   Jan 26 2019, 07:26 PM
Andyrew   You're the first person I've seen that s...   Jan 27 2019, 11:57 AM
Andyrew   You're the first person I've seen that sa...   Jan 27 2019, 03:01 PM
djway   You're the first person I've seen that s...   Jan 28 2019, 03:52 AM
Andyrew   [quote name='Andyrew' post='2684197' date='Jan 27...   Jan 28 2019, 09:13 AM
Chi-town   I was planning on running two ducts closer to the ...   Jan 27 2019, 11:20 AM
mepstein   I would make the opening the way you want and see ...   Jan 27 2019, 04:04 PM
andys   The guiding principle for adequate air flow throug...   Jan 28 2019, 09:41 AM
Jacob   Maybe you could do something similar to the factor...   Jan 28 2019, 09:41 AM
JRust   I think you would be okay. Especially with the ren...   Jan 28 2019, 02:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:19 PM
