| billium01 |
Jan 24 2019, 07:47 PM
Member ![]() ![]() Group: Members Posts: 136 Joined: 12-April 13 Member No.: 15,764 Region Association: None |
Hello,
water cooled 914 here. I have an LS6 motor I'm dropping in. Has anyone ducted a radiator successfully without cutting the front bumper? I'd like to keep the bumper intact and use a front lower valance for an intake. Was going to lay the radiator in the front trunk at an angle. Thanks! Bill |
| Chi-town |
Jan 26 2019, 02:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
You're the first person I've seen that says LS's run hot.
Once you get away from the standard 195 degree + emissions set up it's actually quite easy to keep them cool. The idea I was kicking around was cutting a hole into the floor similar to what the A/C kits do and then ducting through the hood |
| Andyrew |
Jan 27 2019, 03:01 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
You're the first person I've seen that says LS's run hot. Once you get away from the standard 195 degree + emissions set up it's actually quite easy to keep them cool. The idea I was kicking around was cutting a hole into the floor similar to what the A/C kits do and then ducting through the hood My point was they typically run at 215+ but I see your point. I'm sure they are easier to keep cool than a typical SBC. But no front cutout is extremely unlikely to keep cool... There is a damn good reason the rennegade cooling system is the way it is. I would hate to push/pull air from the ground. If you pulled air it would be really hot on a hot summer day and would probably overheat due to the super high ambient temperature of the asphalt at low speeds/idling. And if you pushed air through it then you would just dust the area around you as well as create front end lift at higher speeds. |
| djway |
Jan 28 2019, 03:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
You're the first person I've seen that says LS's run hot. Once you get away from the standard 195 degree + emissions set up it's actually quite easy to keep them cool. The idea I was kicking around was cutting a hole into the floor similar to what the A/C kits do and then ducting through the hood My point was they typically run at 215+ but I see your point. I'm sure they are easier to keep cool than a typical SBC. But no front cutout is extremely unlikely to keep cool... There is a damn good reason the rennegade cooling system is the way it is. I would hate to push/pull air from the ground. If you pulled air it would be really hot on a hot summer day and would probably overheat due to the super high ambient temperature of the asphalt at low speeds/idling. And if you pushed air through it then you would just dust the area around you as well as create front end lift at higher speeds. I had a 2002 Trans Am WS6. The had no nose opening and only a small plastic strip that stuck down only about an inch below the underside bodywork and only about two inches back. Not a large opening at all pulling air right off the road then exiting back under the car. Never had a heat issue no mater the outside temps and how I drove it. That car is also over 4500 pounds. BigKat 83 has a small opening in the body with average wheel well exits, no ducting. LS1 and no heat issues. Most cars the air enters the nose and exits under the car with no real lift. If you place flaps to create a negative pressure in front of a floor exit ( like the flaps in front of the motor compartment) you should create a negative pressure which would actually suck the air out the bottom and you should not really have much lift. Ducting would increase the efficiency. A low entry point actually should pull the air that the rounded valance would push under the car and should cause equal lift if not more. Low air entry and floor exit does not to increase the distance the air travels compared to the air going under the car. The greater distance would be the necessary element in lift. |
| Andyrew |
Jan 28 2019, 09:13 AM
You're the first person I've seen that says LS's run hot. Once you get away from the standard 195 degree + emissions set up it's actually quite easy to keep them cool. The idea I was kicking around was cutting a hole into the floor similar to what the A/C kits do and then ducting through the hood My point was they typically run at 215+ but I see your point. I'm sure they are easier to keep cool than a typical SBC. But no front cutout is extremely unlikely to keep cool... There is a damn good reason the rennegade cooling system is the way it is. I would hate to push/pull air from the ground. If you pulled air it would be really hot on a hot summer day and would probably overheat due to the super high ambient temperature of the asphalt at low speeds/idling. And if you pushed air through it then you would just dust the area around you as well as create front end lift at higher speeds. I had a 2002 Trans Am WS6. The had no nose opening and only a small plastic strip that stuck down only about an inch below the underside bodywork and only about two inches back. Not a large opening at all pulling air right off the road then exiting back under the car. Never had a heat issue no mater the outside temps and how I drove it. That car is also over 4500 pounds. BigKat 83 has a small opening in the body with average wheel well exits, no ducting. LS1 and no heat issues. Most cars the air enters the nose and exits under the car with no real lift. If you place flaps to create a negative pressure in front of a floor exit ( like the flaps in front of the motor compartment) you should create a negative pressure which would actually suck the air out the bottom and you should not really have much lift. Ducting would increase the efficiency. A low entry point actually should pull the air that the rounded valance would push under the car and should cause equal lift if not more. Low air entry and floor exit does not to increase the distance the air travels compared to the air going under the car. The greater distance would be the necessary element in lift. I'm happy to be proven wrong! I just know the difficulty I and many other SBC's have had keeping them cool. One of the biggest reasons for me going away from a v8 was for keeping the engine cool and a usable front trunk. |
billium01 V8 conversion, is it possible to keep the original front bumper completely intact? ie Not cut holes in it. Jan 24 2019, 07:47 PM
Coondog Running a 3.2, with a uncut bumper and a custom cu... Jan 24 2019, 08:04 PM
amfab Well done valence modification! Jan 24 2019, 10:09 PM
djway I have heard of some LS1 swaps without bumper cut ... Jan 25 2019, 12:23 AM
billium01 Thanks for the ideas and info guys. I think the fr... Jan 25 2019, 11:05 AM
Chris H. Yes the Renegade Hybrids valance is nice. It... Jan 25 2019, 11:33 AM
Chris914n6 I use the pre-cut holes behind the valance and the... Jan 25 2019, 01:12 PM
Andyrew LS motors run pretty hot. I don't think you... Jan 25 2019, 01:25 PM
djway
You're the first person I've seen that sa... Jan 26 2019, 07:26 PM
Andyrew
You're the first person I've seen that s... Jan 27 2019, 11:57 AM
Chi-town I was planning on running two ducts closer to the ... Jan 27 2019, 11:20 AM
mepstein I would make the opening the way you want and see ... Jan 27 2019, 04:04 PM
andys The guiding principle for adequate air flow throug... Jan 28 2019, 09:41 AM
Jacob Maybe you could do something similar to the factor... Jan 28 2019, 09:41 AM
JRust I think you would be okay. Especially with the ren... Jan 28 2019, 02:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:49 PM |
