Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
7TPorsh |
Feb 1 2019, 11:11 AM
So did some more hunting and research for a buy vs. build. Decided to buy.
Ordered a high performance 2366cc Type 4/914 long block from SCAT VW; with the clutch kit - no core charge. Sourcing and building a motor like this is going to come out to the same cost or more and this has a warranty. Under $5k Rated at 150-155 hp using Webers. 103mm cylinders, 71mm crank and enlarged valves. I think it's a geat deal. Buying a used running 2.0 engine for $3-4k doesn't seem the way to go for me. Why do a used 2056 with 100hp, when you can get another 50 hp for a little more. Lots of builders on the board here but all start at minimum $5k and go up fast. SCAT has been around for a long time and I've known others with their engines so I feel pretty confident I'll do ok. Any advice on modifying my Weber 40 IDFs and intake for the larger engine? Do people still have intakes polished like in the old muscle car days? Engine drop tonight...anyone looking for a good 1.7 core long block in the LA area? Cheap Cheap! |
thelogo |
Feb 1 2019, 05:30 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
So did some more hunting and research for a buy vs. build. Decided to buy. Ordered a high performance 2366cc Type 4/914 long block from SCAT VW; with the clutch kit - no core charge. Sourcing and building a motor like this is going to come out to the same cost or more and this has a warranty. Under $5k Rated at 150-155 hp using Webers. 103mm cylinders, 71mm crank and enlarged valves. I think it's a geat deal. Buying a used running 2.0 engine for $3-4k doesn't seem the way to go for me. Why do a used 2056 with 100hp, when you can get another 50 hp for a little more. Lots of builders on the board here but all start at minimum $5k and go up fast. SCAT has been around for a long time and I've known others with their engines so I feel pretty confident I'll do ok. Any advice on modifying my Weber 40 IDFs and intake for the larger engine? Do people still have intakes polished like in the old muscle car days? Engine drop tonight...anyone looking for a good 1.7 core long block in the LA area? Cheap Cheap! Air cooled motor assembly requires extremly skilled labor .thats all im saying A |
Lo-Fi Version | Time is now: 31st May 2024 - 05:15 PM |
