aggiezig |
Porsche Wannabe ![]() ![]() Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California ![]() ![]() |
Howdy 914world, looking for some feedback and advice.
I painted my car myself using PPG Concept single stage urethane in Mexico Blue (code 336). This paint was not cheap stuff, but I made sure to put 3-4 wet coats on everything so I'd have plenty of margin to come back after and flatten the peel. I was also under the impression that the color I chose was a solid color, not metallic or pearl. However, I did notice when spraying that there appears to be a very small amount of sparkle in the pigment, which is extremely noticeable if you screw up and paint a run. When I put the last coat of color on my doors, I did exactly that and screwed up with a big run. Frankly, I was rushing and my brain was working a half step ahead of my hands. Anyways, I thought I might be able to sand the run out later as I've seen many times on other projects and YouTube videos. Here is a picture of the run: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1549442246.1.jpg) Long story short, I've run into some issues when wet sanding and buffing out my paint job. It seems I've sanded through the top layer of color in a couple of places. I'm not new to paint correction but maybe I have been misinformed all of this time. I thought the point of spraying many coats of color was to leave a safe amount of paint to sand off afterward when removing orange peel. Is this bad logic? For what it's worth, I'm sanding using 2000 grit paper (1500 in some places, if needed) and able to correct sanding marks with LCC yellow pad on a long throw DA. I thought I'd need my rotary but the sanding marks are coming out easily with Menzerna Heavy Cut 400 on the DA. However, it's clear that I've sanded through the top layer of paint and that the layer underneath does not match. There's also a darker ring of pigment around the transition between the layers. Here is a picture of the door. The light spot, to the bottom right of the camera flash, is where I've gone through the top layer. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1549442247.2.jpg) I've also rubbed through the top layer on an apparent high spot in my front hood. Here is a picture of that. You can imagine how happy I was with myself with I noticed what was going on. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1549442247.3.jpg) I haven't had issues anywhere else on the car, but it's clear I'm going to have to have these two pieces re-sprayed. I'd do it myself but no longer have access to my "spray booth" and pretty sure the VOC paint I used is considered contraband in California. My question is - what exactly is going on here. Am I sanding way too much off? Is there a color match problem? Is my paint actually not a solid color? I want to learn from my mistakes so I don't continue to make them on this very time consuming and expensive paint job. Thanks |
aggiezig |
Many people feel you don't color sand single stage. The solid colors tend to move to the top so if you sand it, you are removing the most important layer. @rick 918-S Interesting, I haven't heard this before but could explain what's going on here. I also thought I read somewhere to avoid color sanding into any metal flake as well since you would be altering the shape or profile of the flakes thus creating color problems as well. Definitely, have read/heard this. I'm still not convinced exactly what this paint is. It looks like a solid color to me, but then again I've seen a slight metallic sparkle in the pigment when it builds up. Who knows. Do it by hand, not with a machine. You can feel the surface better. You are also less likely to sand thru. Definitely agree with this and have been sanding by hand with foam blocks I live in LA and you can paint up to 3 gallons a day and be ok. HVLP sprayguns are exempt. Just be cool about it to not attract attention. Good to know. Can I still purchase non-VOC compliant paint out here? The stuff I sprayed it with (PPG Concept) was definitely not "low VOC" Our shop painter said 3-4 coats isn’t much. Especially if the paint isn’t top of the line. He said you don’t want to color sand single stage if you don’t have to but if you are a newbie, you might have to. Never sand metallic. Good advice, this is why I went for the "upgraded" paint and picked Concept over Shop Line. I'm not sure that the number of coats really mattered in my case seeing as just sanding through one of the coats is showing problems. --- Thank you everyone for the feedback |
Lo-Fi Version | Time is now: 19th July 2025 - 09:07 PM |
