| dcecc1968 |
Feb 6 2019, 07:46 AM
Member ![]() ![]() Group: Members Posts: 256 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
We are having some Spring weather this week in Charlotte, NC (and no rain!) so I've been driving the 914 and noticed that after about 20 minutes of driving, the valves intermittently knock from "normal" to very loud for no apparent rhyme or reason.
Outside of the obvious that it may be time for a valve adjustment, I wondered what Gasoline grade folks are using. What Petro are you using in your 914? |
| Mikey914 |
Feb 7 2019, 02:22 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I only run ethanol free and additive for lubrication (as we are lead free now).
These engines were designed with leaded gas on mind. |
dcecc1968 Gasoline - 90 Octane, Ethanol Free (89), or additives Feb 6 2019, 07:46 AM
TheCabinetmaker Check your timing Feb 6 2019, 07:54 AM
BeatNavy A well-tuned stock engine (with stock compression ... Feb 6 2019, 07:58 AM
porschetub Loose valves are a clatter/rattle not a knocking,i... Feb 6 2019, 12:34 PM
914_teener
Loose valves are a clatter/rattle not a knocking,... Feb 6 2019, 12:55 PM
Dave_Darling If it really is valve noise, the probable causes r... Feb 6 2019, 01:13 PM
dcecc1968 Thanks for your suggestions. I will definitely ch... Feb 6 2019, 02:17 PM
wndsrfr
Thanks for your suggestions. I will definitely c... Feb 6 2019, 03:34 PM
bbrock At what compression should you start thinking abou... Feb 7 2019, 10:21 AM
Dave_Darling
Side question: Anyone know why they raised the oc... Feb 7 2019, 03:52 PM
Mark Henry
Side question: Anyone know why they raised the o... Feb 8 2019, 12:21 PM
914Sixer Check around at Pure Gas.com and see if there is a... Feb 7 2019, 01:12 PM
jfort this thread is close to my question so I'll co... Jul 11 2019, 02:17 PM
FlacaProductions @mikey914 - what additive do you use?
this car is... Jul 11 2019, 06:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st August 2026 - 08:06 AM |
