| bbrock |
Feb 7 2019, 08:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
The factory manual and PET show an overflow tube from the brake reservoir. None of my 914s had them so I've never seen one. Did they really exist? If so, how were they attached? I see the vent on my reservoir but no place to attach a tube. I can't see anyplace that looks like something broke off either. (IMG:style_emoticons/default/confused24.gif)
| theer |
Feb 8 2019, 09:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
My '72 has a vent tube, too.
BTW, you'll need the tube in order to block off the vent if you ever want to pressure bleed. Yep, found that out the hard way.. |
| isdyl |
Feb 9 2019, 05:10 PM
Member ![]() ![]() Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Yes me too! I used a pressure bleed system recently without realising and had a pint of brake fluid shoot down to the garage floor in five seconds!
My '72 has a vent tube, too. BTW, you'll need the tube in order to block off the vent if you ever want to pressure bleed. Yep, found that out the hard way.. |
bbrock brake reservoir overflow tube Feb 7 2019, 08:25 PM
mepstein I think the early cars had the overflow tube and t... Feb 7 2019, 08:37 PM
altitude411 :agree:
I believe only the early cars (end of ... Feb 7 2019, 09:22 PM
Matty900 :agree:
I believe it was also used on the early 9... Feb 8 2019, 02:02 AM
rgalla9146
The factory manual and PET show an overflow tube ... Feb 8 2019, 07:18 AM
914Sixer Rory,
Try some fuel line for model airplane engine... Feb 8 2019, 07:22 AM
1970 Neun vierzehn brake fluid reservoir vent tube installation on a ... Feb 8 2019, 07:46 AM
Chi-town I have two early reservoirs with the drain tubes Feb 8 2019, 09:00 AM
bbrock Thanks guys. Good to know and at least not an ite... Feb 8 2019, 09:07 AM
rgalla9146
Thanks guys. Good to know and at least not an it... Feb 9 2019, 07:30 AM
bbrock Thanks Rory. I'm doing my best to keep up wit... Feb 9 2019, 02:35 PM
rgalla9146 Follow up on this thread.
Be sure to use the c... Feb 21 2019, 11:34 AM
mgphoto My ‘72 built late May doesn’t have the vent ho... Feb 21 2019, 01:56 PM
913B To source that tube you can go to the local pet st... Feb 21 2019, 08:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2025 - 07:14 AM |
