| 914 RZ-1 |
Jan 25 2019, 11:32 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm starting to put my car back together after painting it. I had a hard time getting one of the turn signal boots off. My questions are:
1. Do I need to take off the spade connectors? Seems like it would be easier to remove them and also to re-insert the wires back into the rubber boots. 2. Where can I get QUALITY 6.3mm Female Spade Crimp Terminal Connectors? Amazon has them for about $0.06 each, but the reviews are mixed. Some sites have them for about $0.25 EACH! Lowes/Home Dept do not have the type I need: the ones that have the wires crimped on with a special crimper, not smashed on with pliers. Look at your wire connections and you'll see what I'm talking about. I'd like to find some sort of electrical supply place. I used to get this stuff at Radio Shack. Where is the new Radio Shack-like place to get electronic parts? 3. Is there a trick to cutting off/removing the rubber boots? Took me an hour off cutting with wire cutters, a razor knife, pliers, etc. I finally realized I could pull the wires thru the boot after dabbing a little lube (Tri-Flow) between the boot and the wires. Did I just answer my own question? Thought I'd ask before going on. I still have to do the taillights and headlights. |
| Mikey914 |
Feb 10 2019, 05:19 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Highly recommend replacing g the boots while the ends are off while you are doing this. Most are crap.
Got both of you need them. Mark |
914 RZ-1 changing out turn signal boots Jan 25 2019, 11:32 PM
bbrock I think you did answer your own question. I insta... Jan 26 2019, 01:19 AM
Tbrown4x4 I just put 914Rubber boots on the front markers an... Jan 26 2019, 09:28 AM
Matty900 There is a short cut coming soon Jan 27 2019, 12:48 AM
tmc914
Think I am goin... Feb 10 2019, 07:35 PM
914 RZ-1 Here's what I did after getting frustrated aft... Feb 2 2019, 04:16 PM
campbellcj Thanks as well re. the digikey reference and this ... Feb 10 2019, 10:45 AM
IronHillRestorations I've found that a small set of snap ring plier... Feb 11 2019, 08:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 01:14 PM |
