> 914World Classifieds Rules
> 914 2.0 core engine SOLD 2.0 with sheetmetal $650., 1.8 big valve heads SOLD
914ltd
post Feb 10 2019, 02:44 PM
The GA engine is a long block and doesn't turn. $400. plus ship SOLD
The other engine is a 1.8 numbered block with 2.0 heads that was built for a track car. Includes distributor and alternator clutch and flywheel. I removed it in running condition but the compression was low. Includes sheet metal. $650. plus ship Pair of 1.8 big valve heads with double valve springs, the heads have been bored to 112mm for an oversize piston/cylinder. I measured the valves 39 and 47mm but they are probably 38 and 48. The seats almost touch and there is a open spot in the aluminum between them. I don't know if this is normal? $110. for the pair plus ship.
Brad Mayeur
Heads SOLD
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
pneuhyde
post Feb 10 2019, 11:26 PM
QUOTE(914ltd @ Feb 10 2019, 01:44 PM) *
Brad Mayeur
Hi Brad,
Would these heads work with 96mm piston/cyl's and what do you mean by "an open spot in the aluminum between them"
Thank you,
Steve
- Lo-Fi Version Time is now: 19th September 2026 - 07:51 PM
