THE COLONEL Questions!, Wiring loom/harness?? |
Stoddy |
Feb 10 2019, 08:48 AM
All things Porsche! Group: Members Posts: 53 Joined: 30-May 18 From: Monmouth (UK) Member No.: 22,173 Region Association: England |
Hello folks,
I've a couple of questions that I've thought of whilst sipping tea and dismantling the Colonel. Is it wise, common practice, adviseable, to replace the original wiring? or, should I test it and then put it back if it all works? Are there any other parts which should be replaced, period? like relays, things like that? And finally, for now, the petrol tank....whats the best way to re condition that? looks quite cruddy in there, but very little rust seems to be present on either the outside, or the inside. I removed a couple of litres of VERY stinky old fuel already. Thanks in advance! Stoddy (IMG:style_emoticons/default/type.gif) |
Stoddy |
Feb 11 2019, 04:51 AM
Thanks gents, I'll check out the local radiator shop and take it from there.
It's best to remove the harness completely i'm guessing, when I do a full shell respray? Stoddy (IMG:style_emoticons/default/smile.gif) |
Jonathan Livesay |
Feb 11 2019, 05:28 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Thanks gents, I'll check out the local radiator shop and take it from there. It's best to remove the harness completely i'm guessing, when I do a full shell respray? Stoddy (IMG:style_emoticons/default/smile.gif) If you want it to look like a 100% new car then yes. However a used harness is even harder to put back than a new one because it's a lot stiffer and more brittle. Unless you're going for a 100 point car you can get a good look by bagging the rear wiring at the firewall and the front wiring in the bottom of the gas tank well. |
Stoddy |
Feb 11 2019, 05:47 PM
Thanks gents, I'll check out the local radiator shop and take it from there. It's best to remove the harness completely i'm guessing, when I do a full shell respray? Stoddy (IMG:style_emoticons/default/smile.gif) If you want it to look like a 100% new car then yes. However a used harness is even harder to put back than a new one because it's a lot stiffer and more brittle. Unless you're going for a 100 point car you can get a good look by bagging the rear wiring at the firewall and the front wiring in the bottom of the gas tank well. Thanks Jonathan, I think I'll test the harness, then leave it in situ like you suggest.I remember re shelling an MGBGT and the harness was a complete pig to get back in. Thanks for the tip! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 07:21 AM |
