> Lifts, 2 Post Hydraulic Lift Questions
ctc911ctc
post Feb 14 2019, 11:25 AM
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear.
I am thinking about installing a 2 post lift where each post would be against the walls, out of the way.
I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift.
1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)?
2. How deep do the anchors need to be placed into the floor? Very little detail on web sites.
3. Are there any preferences as to vendors? I have been looking at this one:
https://www.toolots.com/two-post-car-lift-l...#productDetails
My requirements are that the lift be as small (footprint) and safe as possible.
THANK YOU ALL TEENERS!
CTC911CTC
John
post Feb 15 2019, 12:45 PM
member? what's a member?
Each of the two Rotary lifts (7,000# and 10,000#) are clear floor, asymmetrical two post lifts. Each of them (and many others) call for a minimum of 3,000 PSI concrete with a minimum thickness of 4 1/2". They both require 3/4" concrete anchors with a minimum length of 5 1/2" with a minimum anchor embedment of 3-1/2".
The anchors must be properly installed and the torque rating is supposed to be at least 150 ft-lbs.
My floor is more than 6" thick and I had no problems drilling and torquing my anchor bolts to my floor when I installed my lifts. At least Rotary Lifts does have ways of making the lifts fit low ceiling clearance, and narrow or wide bays, but lift height might be affected.
ctc911ctc   Lifts   Feb 14 2019, 11:25 AM
BPic   I have this one: https://www.maxjaxusa.com/buy-pu...   Feb 14 2019, 11:32 AM
mepstein   The lift should have specific installation instruc...   Feb 14 2019, 12:14 PM
ClayPerrine   You are not going to get most two post lifts under...   Feb 14 2019, 12:59 PM
ctc911ctc   Not going to happen, brick carriage house, rebuild...   Feb 14 2019, 01:02 PM
ClayPerrine   They make a few short versions of the two post lif...   Feb 14 2019, 04:00 PM
jvmarino   Max Jax is pretty much your only option. That is w...   Feb 14 2019, 07:18 PM
wndsnd   I agree Max Jack is fantastic at that ceiling heig...   Feb 14 2019, 07:35 PM
mepstein   I agree Max Jack is fantastic at that ceiling hei...   Feb 14 2019, 08:47 PM
rgolia   I agree Max Jack is fantastic at that ceiling hei...   Feb 15 2019, 09:53 AM
cuddy_k   Quick Jack is another great option. The lift secti...   Feb 15 2019, 06:25 AM
mb911   Quick Jack is another great option. The lift sect...   Feb 17 2019, 09:28 AM
ctc911ctc   On my list - went to buy it today - price raised t...   Apr 3 2019, 08:10 AM
mgphoto   I decided on the EZ Car lift, light weight, very p...   Feb 15 2019, 08:47 AM
ctc911ctc   After carefully considering what was posted, my li...   Feb 15 2019, 10:22 AM
John   Each of the two Rotary lifts (7,000# and 10,000#) ...   Feb 15 2019, 12:45 PM
Chi-town   If you can't go up, what about down? Cut the ...   Feb 15 2019, 02:25 PM
mepstein   If you can't go up, what about down? Cut the...   Feb 15 2019, 02:55 PM
ctc911ctc   Good thing I am an engineer! The concrete is ...   Feb 15 2019, 08:07 PM
sithot   Expensive but possible an option. Might have to ...   Feb 16 2019, 09:37 AM
Mark Henry   There's a one post lift, plus it can be rolled...   Feb 16 2019, 08:47 AM
burton73   There's a one post lift, plus it can be rolle...   Feb 17 2019, 12:20 PM
mepstein   There's a one post lift, plus it can be roll...   Feb 17 2019, 03:27 PM
ledfoot   The Maxjax works with the 3” pad extension for...   Feb 16 2019, 09:58 AM
ctc911ctc   The Maxjax works with the 3” pad extension fo...   Feb 16 2019, 11:56 AM
r_towle   The Maxjax works with the 3” pad extension f...   Feb 17 2019, 03:49 PM
mepstein   [quote name='ctc911ctc' post='2689468' date='Feb ...   Feb 17 2019, 04:02 PM
mb911   [quote name='ctc911ctc' post='2689468' date='Feb...   Feb 17 2019, 04:21 PM
ClayPerrine   [quote name='mepstein' post='2689907' date='Feb 1...   Feb 18 2019, 07:10 AM
mepstein   [quote name='mepstein' post='2689907' date='Feb ...   Feb 18 2019, 07:18 AM
ClayPerrine   [quote name='ClayPerrine' post='2690041' date='Fe...   Feb 19 2019, 06:52 AM
Mark Henry   [quote name='ClayPerrine' post='2690041' date='Fe...   Feb 20 2019, 02:37 PM
mepstein   [quote name='ClayPerrine' post='2690041' date='F...   Feb 20 2019, 02:44 PM
ClayPerrine   [quote name='Mark Henry' post='2690809' date='Feb...   Feb 21 2019, 02:45 PM
sithot   Bendpak: https://www.bendpak.com/grandprix/   Feb 23 2019, 09:07 AM
steuspeed   Single side option. https://aclifts.com/lifts/m-...   Feb 17 2019, 03:43 PM
AHudson   Quick Jack is another great option. The lift sect...   Feb 18 2019, 07:57 AM
mepstein   Any lift is better than jack stands.   Feb 18 2019, 08:01 AM
North Coast Jim   All, I am rebuilding the garage, very small NE g...   Feb 18 2019, 11:19 AM
Triaddave   If the ceiling is the limit on going up, build a p...   Feb 18 2019, 12:41 PM
mepstein   If the ceiling is the limit on going up, build a ...   Feb 18 2019, 01:31 PM
cuddy_k   Maxjax is a great option if you like/need to work ...   Feb 18 2019, 01:30 PM
dan10101   When I turned 50 I petitioned for a rack. I chose...   Feb 19 2019, 09:22 PM
ctc911ctc   When I turned 50 I petitioned for a rack. I chos...   Feb 20 2019, 12:16 PM
TheWeatherMan   When I turned 50 I petitioned for a rack. I chos...   Feb 26 2019, 02:11 PM
dr914@autoatlanta.com   after looking at many many many lifts and lift man...   Feb 23 2019, 09:51 AM
sithot   after looking at many many many lifts and lift ma...   Feb 23 2019, 10:34 AM
mb911   Just bought a maxjax for 1500 today delivered.. Wa...   Feb 26 2019, 05:31 PM
mepstein   Just bought a maxjax for 1500 today delivered.. W...   Feb 26 2019, 05:34 PM
DRPHIL914   Just bought a maxjax for 1500 today delivered.. W...   Feb 27 2019, 08:19 AM
mb911   Just bought a maxjax for 1500 today delivered.. ...   Feb 27 2019, 11:18 AM
Freezin 914   As some of you know, I just bought a mid rise lift...   Feb 26 2019, 06:14 PM
Mark Henry   One thing I don't like about some of the sciss...   Feb 27 2019, 06:07 AM
Carl La Fong   Mid size lifts are great. This garage has a 7 fo...   Apr 3 2019, 10:15 AM
rhodyguy   Welcome back Elliot! You've been missed ...   Apr 3 2019, 11:22 AM
76-914   Welcome back Elliot! You've been missed ...   Apr 3 2019, 12:52 PM
Carl La Fong   Welcome back Elliot! You've been missed ...   Apr 3 2019, 02:46 PM
Mark Henry   Welcome back Elliot! You've been missed ...   Apr 3 2019, 02:54 PM
Krieger   Welcome back Elliot! You've been missed ...   Apr 3 2019, 10:41 PM
rhodyguy   Man...that's a lot of quotes. Quote happy Wedn...   Apr 3 2019, 01:01 PM
Carl La Fong   I have no idea who you are all talking about.   Apr 3 2019, 02:48 PM
sb914   I have no idea who you are all talking about. I ...   Apr 3 2019, 04:29 PM
Hans Zupp   I have no idea who you are all talking about.I do...   Apr 25 2019, 09:34 AM
914-300Hemi   I just placed an order for a MaxJax 2 post lift. L...   Apr 3 2019, 09:41 PM
mb911   I just placed an order for a MaxJax 2 post lift. ...   Apr 4 2019, 05:46 AM
76-914   I'm lucky there. My hose slips into the recess...   Apr 4 2019, 08:34 AM
mlindner   Ben, just get a cement blade for your circular saw...   Apr 4 2019, 12:15 PM
914_teener   Ben, just get a cement blade for your circular sa...   Apr 4 2019, 12:24 PM
mepstein   Hose Protector Ramp - sold on Amazon   Apr 4 2019, 12:26 PM
mlindner   Ben, found a better shot before I filled the grove...   Apr 4 2019, 12:26 PM
mlindner   914 teener. Bendpak, 6,000 lbs. love it.   Apr 4 2019, 12:29 PM
mlindner   ctc911ctc, just looking at your garage size again....   Apr 4 2019, 01:11 PM
914_teener   ctc911ctc, just looking at your garage size again...   Apr 4 2019, 03:26 PM
Mark Henry   ctc911ctc, just looking at your garage size agai...   Apr 5 2019, 06:10 AM
mlindner   Just noticed, two out of the three two post lifts ...   Apr 4 2019, 01:29 PM
mb911   @mlinder I suppose I could do that.. Not a bad id...   Apr 4 2019, 03:08 PM
Dredwin   I embraced my hose...bought a pool noodle, cut it ...   Apr 4 2019, 03:50 PM
mlindner   914 teener, good question and I do have a Cayman.....   Apr 5 2019, 05:12 AM
mlindner   I agree Mark, with doing that much work...trans, e...   Apr 5 2019, 07:01 AM
Krieger   Now I am considering the move to the two post lift...   Sep 28 2019, 10:43 AM
ClayPerrine   Now I am considering the move to the two post lif...   Sep 28 2019, 08:19 PM
914-d   One of the lifts I have is 110v, the other is 220v...   Sep 28 2019, 10:58 AM
mb911   The maxjax works on 110 .. I have used all kinds a...   Sep 28 2019, 08:32 PM
oldschool   I got this off of crags list its a tire chief has...   Sep 29 2019, 01:07 AM
sithot   A friend has put these in his latest dealership. ...   Sep 29 2019, 05:39 AM
ClayPerrine   FWIW: It's apparently a little known fact t...   Sep 29 2019, 12:21 PM
mb911   I need one that is about 48" might have to ma...   Sep 29 2019, 12:52 PM
sithot   I need one that is about 48" might have to m...   Sep 29 2019, 03:23 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:34 AM
