side passenger window install question, rubber piece or urethane caulk? |
914 RZ-1 |
Feb 16 2019, 03:29 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I found the thread on installing the side windows (not the little triangular ones, but the big ones). They state to use urethane caulk (3M Windo-Weld # 08609) to attach them to the rail on the window mechanism. However, the factory install uses a rubber u-channel.
I'd rather use the u-channel, since it doesn't appear that using the caulk allows for any adjustment fore and aft after it cures. My windows were taken out to paint the car so I have no reference for putting them back. The window install post stated to measure about 4-3/16" (106mm) from the front, but what is the tolerance? I'm thinking there could be some variance in location plus or minus 1/4" (6mm). I thought of setting the window in place, but I won't have the triangle window in, so there will be nothing to reference the location off of. Any ideas on solutions? Where can I get the u-channel? Also, is the u-channel glued in or just friction-fit? |
914 RZ-1 |
Feb 17 2019, 11:30 AM
The metal parts I have are in great shape. I only have one rubber channel. I thought I might try and find some rubber sheet and make another channel.
The 3M caulk is $31a tube, so I thought I'd try an alternative first. I want adjustability as well; the caulk doesn't give me that. |
jsaum |
Feb 17 2019, 04:13 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
The metal parts I have are in great shape. I only have one rubber channel. I thought I might try and find some rubber sheet and make another channel. The 3M caulk is $31a tube, so I thought I'd try an alternative first. I want adjustability as well; the caulk doesn't give me that. Can you post a picture of the rubber u channel? |
Lo-Fi Version | Time is now: 10th June 2024 - 11:10 AM |
