| clapeza |
Feb 19 2019, 12:23 PM
Member ![]() ![]() Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States
Found a 1987 924S for sale. 67k miles, idles smoothly, AC works, brakes evenly, shifts good. Dash has usual cracks at leading edge. Rear glass looks good. Guy wants $6k for it.
Found some water (!) in the rear pocket behind the passenger right wheel - leaking sunroof drain hose? Anything in particular that needs to be checked on these cars? What's their "Hell hole"? I know these use the same block as the 944 and maintenance is similar as a 944. Thanks! |
| dr914@autoatlanta.com |
Feb 19 2019, 12:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Found a 1987 924S for sale. 67k miles, idles smoothly, AC works, brakes evenly, shifts good. Dash has usual cracks at leading edge. Rear glass looks good. Guy wants $6k for it. Found some water (!) in the rear pocket behind the passenger right wheel - leaking sunroof drain hose? Anything in particular that needs to be checked on these cars? What's their "Hell hole"? I know these use the same block as the 944 and maintenance is similar as a 944. usually the leak is a sunroof drain clogged but could be the rear hatch leaking, have to check that because the glass frame separates sometimes, and is not easy to repair. You need to make sure that the timing belt has been changed and properly tensioned. The car is galvanized so there is no problem (usually) with rust, although you must check the drains at the cowl under the hood as the battery acid could eat a hole through because of standing water and leak into the pass compartment, and on the other side render the wiper motor useless if it gets water logged. the 924 s is a really good car, you may want to get the 924 944 tech tips book for some further advice and information. Thanks! |
clapeza OT: 1987 924S Feb 19 2019, 12:23 PM
Ferg Clutch, Timing Belt and Water pump are the biggest... Feb 19 2019, 12:29 PM
Racer http://www.clarks-garage.com/
944 drivetrain in n... Feb 19 2019, 01:41 PM
ConeDodger If the miles are real, it’s possible the clutch ... Feb 19 2019, 02:19 PM
Dion :agree: with all the above. Also that water in com... Feb 19 2019, 02:33 PM
Tdskip I had one of these, quite a good car if understate... Feb 19 2019, 03:14 PM
Ansbacher I owned an '88 924S for 13 years before it was... Feb 20 2019, 12:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:03 AM |
