wiring for door light, need help with connections |
914 RZ-1 |
Feb 16 2019, 04:22 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
914sgofast2 |
Mar 1 2019, 10:06 PM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I suspect you have a dead short in the wiring going to the interior lamp and when the wire from the door is grounded, it shorts out the circuit. Is the interior lamp connected the right way? Is the wiring to the door buzzer disconnected or shorting out?
914 RZ-1 |
Mar 1 2019, 11:18 PM
I suspect you have a dead short in the wiring going to the interior lamp and when the wire from the door is grounded, it shorts out the circuit. Is the interior lamp connected the right way? Is the wiring to the door buzzer disconnected or shorting out? Lamp has no bulb, but it appears to be connected correctly. I've never heard the door buzzer go off so I might not have one. I'll check and report back. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:11 PM |
