Deck Height and Valve Relief, What would you do? |
BeatNavy |
Mar 4 2019, 06:44 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
While I wait (seemingly forever) for back-ordered rocker shims to arrive from aircooled, I keep debating in my head which way to go on deck height on a 2056 rebuild I am doing:
CC volume is 59.8 (calculated by Len Hoffman) Raby 9950 (FI) cam JE Pistons with valve relief Deck height w/o any barrel shims is .032. That gives me a CR of 8.6, assuming the valve relief adds about 2 cc's to CC volume. Adding a .010 shim puts me just shy of 8.4 CR with a deck height of .042. .042 deck height is safer. Pretty sure I wouldn't go .032 deck height with flat tops, but does the valve relief give me enough "safety?" This is my first Type 4 rebuild, so maybe I should go conservative? Am I crazy considering going less than .035? I've done the "clay test" with deck height at .042, and there's no issue there. What would you do? |
BeatNavy |
Mar 5 2019, 10:01 AM
Thanks, Zach. No head gasket. I did the play-doh with the barrel ship installed and deck height of 042. No issues. Just wondering if .032 was too close even with valve relief. I should have planned it a little better ahead of time with the machinist, but it should still be all good.
Lo-Fi Version | Time is now: 9th June 2024 - 02:07 PM |
