Deck Height and Valve Relief, What would you do? |
BeatNavy |
Mar 4 2019, 06:44 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
While I wait (seemingly forever) for back-ordered rocker shims to arrive from aircooled, I keep debating in my head which way to go on deck height on a 2056 rebuild I am doing:
CC volume is 59.8 (calculated by Len Hoffman) Raby 9950 (FI) cam JE Pistons with valve relief Deck height w/o any barrel shims is .032. That gives me a CR of 8.6, assuming the valve relief adds about 2 cc's to CC volume. Adding a .010 shim puts me just shy of 8.4 CR with a deck height of .042. .042 deck height is safer. Pretty sure I wouldn't go .032 deck height with flat tops, but does the valve relief give me enough "safety?" This is my first Type 4 rebuild, so maybe I should go conservative? Am I crazy considering going less than .035? I've done the "clay test" with deck height at .042, and there's no issue there. What would you do? |
ChrisFoley |
Mar 5 2019, 10:13 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I doubt you need valve reliefs with the FI camshaft either way.
Lo-Fi Version | Time is now: 10th June 2024 - 01:03 AM |
