Are these 1.8L L-Jet ECU's interchangeable? |
Jason74914 |
Mar 5 2019, 08:30 PM
Member Group: Members Posts: 76 Joined: 9-January 16 From: Dallas Member No.: 19,544 Region Association: None |
1974 1.8L with stock L-Jet Bosch FI
I need to replace or repair my ECU which has the following on the label: Bosch part # 0-280-000-103 Porsche # 022-906-012-G I've located a 1974 1.8L donor car (inoperable and history unknown): It's ECU has a label with: Bosch part # 0-280-000-111 So, the difference in the Bosch # is last three digits: "103" vs "111" Also, the donor ECU does not have the Porsche # on the label, but I tried to cross-reference, and I'm coming up with: 022-906-012-B So, difference in Porsche # is only the last letter: "G" vs. "B" Interweb shows the "B" associated with a 1975-76 VW Bus or 914. (I have no idea why the donor car--which is definitely a 1974--has the "111/B" ECU in it.) Question: Can I replace my "103/G" ECU with the "111/B" ECU? Thanks, Jason |
Jason74914 |
Mar 6 2019, 08:39 AM
Thanks guys!
Sort of what I thought. I do have the chance to grab the AFM off of the donor car as well, so I will just do that, and either way I should have the correct combination of ECU and AFM. Final question, is the throttle body any different? Thanks again, Jason |
ClayPerrine |
Mar 6 2019, 09:37 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Thanks guys! Sort of what I thought. I do have the chance to grab the AFM off of the donor car as well, so I will just do that, and either way I should have the correct combination of ECU and AFM. Final question, is the throttle body any different? Thanks again, Jason Throttle body switch is the same. Make sure you grab the L-Jet harness to match the AFM and the ECU. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:35 AM |
