Clutch issue or something more?, Need to erase the grind |
MiniStevieG |
Feb 10 2019, 05:17 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Experiencing some issues when shifting gears. I’m finding that even with the clutch pedal pressed the entire way to the floor I’m grinding a bit when shifting. I did a bit of research and decided to adjust the tensioner on the back cable assembly.
First I tried tightening the nut thinking this would help the clutch to engage sooner but in fact the issue appeared worse after I tightened it. I then adjusted the nut back to where I started and tried loosening it but that didn’t help either. Anyone care to take a stab at what the issue might be? New cable assembly maybe? Pressure plate? Thanks everyone!! |
rhodyguy |
Feb 12 2019, 05:46 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Is this a 1st/R thing or all gears?
SteelerMike77 |
Mar 10 2019, 09:16 AM
Newbie Group: Members Posts: 24 Joined: 12-February 19 From: Mountville, Pa Member No.: 22,874 Region Association: MidAtlantic Region |
Is this a 1st/R thing or all gears? Hello, I AM having a shifting problem with ONLY 1ST & Reverse... they grind sometimes, more reverse... any suggestions? Also, I have a little seepage of gear oil coming out where the shift linkage goes into the gear box...ant thought? Thanks |
Lo-Fi Version | Time is now: 17th June 2024 - 12:15 AM |
