FS Shiny and Powder Coated Parts, Multiples of some parts |
bdstone914 |
Mar 10 2019, 07:32 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
One set of 16 original alloy lug bolts.
Size: 14m x 38m. Replated silver zinc. $150 shipped. Sets of fuel rails and injector hold down clamps. Silver or gold. Several sets $35 for a set of 4 clamps and two rails. Attached thumbnail(s) |
bdstone914 |
Mar 10 2019, 07:34 PM
One pair of early 1970-1972 front strut shaft lock plates. Correct for a 914-6
Edit, Found a second set of late strut plates. SOLD Porsche changed the design to the larger plate. They fit all cars. $25 a pair. Edit, checking for more Sold $25 a set. Attached thumbnail(s) |
bdstone914 |
Mar 10 2019, 07:35 PM
Rear trailing arm bracket L plates. $20 a pair
With new 10m x 55m 10.9 grade bolts and Schnorr washers. $35 for the set. Pictures to follow. MAP sensor bracket. Powder coated. $15 each. Two available. Steering rack bearing yoke. Holds steering rack shaft bearing to the body. $10. Clutch forks. 901 transmissions. Tail or side shift. SOLD $ Attached thumbnail(s) |
AHudson |
Mar 11 2019, 03:05 PM
Member Group: Members Posts: 55 Joined: 13-May 18 From: Alabama Member No.: 22,112 Region Association: South East States |
Rear trailing arm bracket L plates. $20 a pair With new 10m x 55m 10.9 grade bolts and Schnorr washers. $35 for the set. Pictures to follow. MAP sensor bracket. Powder coated. $15 each. Two available. Steering rack bearing yoke. Holds steering rack shaft bearing to the body. $10. Clutch forks. 901 transmissions. Tail or side shift. $30 each. Three available. Just PM'd you: will take a clutch fork for a 901 tail shift. Thanks! |
Lo-Fi Version | Time is now: 8th June 2024 - 10:23 PM |
