How do I....?, I need to create a "switched" ciruit |
Carlitos Way |
Nov 26 2004, 02:16 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
For some unknown reason, the PO had run the fuel pump off the Tail Light circuit, so I need to correct this. I tried other fuses in the fuse box, but they all seem to be either on all the time, or only on when specific things are turned on. So I decided to do things "better."
I would like to run a "switched" circuit to my fuse box, so I can have the fuel pump active only when the engine is running (ignition in the ON position?). I have upgraded to the 15 fuse box and would like to create two new switched fuse circuits for my fuel pump and my stereo (one each), that way I can get ahead of the game, and know exactly where everything is, rather than splicing more stuff and screwing around with the electrical system. Can you help/offer any suggestions? |
TheCabinetmaker |
Nov 26 2004, 06:38 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Thanks Daniel. Believe it or not, that does make sense. I did know the 3rd controled the FI, but was not aware it was powered by #2
Lo-Fi Version | Time is now: 17th June 2024 - 02:29 AM |
