| twistedstang |
Mar 14 2019, 01:48 PM
Member ![]() ![]() Group: Members Posts: 229 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None
I'm finishing up my five lug swap and hit a wall. On the aluminum 911 hubs, is it proper to use a split washer on the aluminum hub when bolting on the rotor? If so, should I run the bolt through the hub first so the split washer is on the rotor side instead? I'm worried they will mar the aluminum.
| bdstone914 |
Mar 15 2019, 03:19 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,379 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Spring washers are correct. The bolt goes through from the rotor side with the nut and washer against the hub.
Bruce |
twistedstang 911 front hubs- split washers or no Mar 14 2019, 01:48 PM
yeahmag I use a flat washer and non-locking 8mm nut torque... Mar 14 2019, 02:28 PM
mb911 I use spring washers no split washers. Mar 14 2019, 02:53 PM
sixnotfour 2 900 075 079 02 Hexagon-head bolt 10 914-6
M 8 X ... Mar 14 2019, 03:45 PM
twistedstang Thanks everyone. I'll be on the hunt today for... Mar 15 2019, 05:33 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th September 2026 - 06:08 AM |
