> Seat Frame: New Challenge, Reassembly & Seat Handle Rails
914_7T3
post Mar 2 2019, 12:58 PM
Looking to have my seat frames powder coated and need to remove the non-painted handle assembly as it contains plastic bushings that will melt at high temperature.
Any idea on the correct procedure and tools required for removal?
bbrock
post Mar 17 2019, 07:36 PM
First. Make sure you have plenty of coins to put in the swear jar because you will use ALL of your words. Those little springs are almost as nasty as the trunk torsion bars and I damn near lost a thumb on the first one I did. Not sure if anyone has a better trick, but I wound up just using a needle nose vice grip on the hook part to reef it up around that pin. Hated to do it on a freshly replated spring but I tried many other approaches first, including the one that I think literally cracked the end of my thumb bone and another that resulted in a slipped screw driver and a nice scratch in my freshly painted frame.
On painting the handle, I'd also like to know how hard it is to take apart and put back together. I wound up leaving it on. I cleaned the rail really good and then masked it off to spray the handle satin black. It came out really nice. I'm guessing you could find a replacement rivet so you could just drill out the old one and separate the parts, but something about those rivets intimidates me.
914_7T3
post Mar 17 2019, 08:13 PM
QUOTE(bbrock @ Mar 17 2019, 06:36 PM) *
Ok, so does that mean securing the spring to the rail first and then wrapping it on the pin? You have to explain it like I'm 6 years old.
I opted not to replate the hardware under the seat frame as they have a bit of a chrome finish. Used steel wool & oxalic acid and they came out pretty clean, but still shows their age. As for the handles, I will do same and not bother over complicating it.
914_7T3   Seat Frame: New Challenge   Mar 2 2019, 12:58 PM
bbrock   Just a drift to drive out the roll pin that the sp...   Mar 2 2019, 02:03 PM
914_7T3   Just a drift to drive out the roll pin that the s...   Mar 2 2019, 02:32 PM
914_7T3   Got the frames back from Powder Coating and cleane...   Mar 17 2019, 07:26 PM
bbrock   First. Make sure you have plenty of coins to put ...   Mar 17 2019, 07:36 PM
914_7T3   First. Make sure you have plenty of coins to put...   Mar 17 2019, 08:13 PM
bbrock   Ok, so does that mean securing the spring to the ...   Mar 17 2019, 09:24 PM
914_7T3   Ok, so does that mean securing the spring to the...   Mar 17 2019, 10:21 PM
mepstein   Didn't 914rubber make a tool for winding or se...   Mar 17 2019, 08:31 PM
914_7T3   Didn't 914rubber make a tool for winding or s...   Mar 17 2019, 08:39 PM
mepstein   [quote name='mepstein' post='2697677' date='Mar 1...   Mar 17 2019, 08:48 PM
914_7T3   [quote name='914_7T3' post='2697679' date='Mar 17...   Mar 17 2019, 10:25 PM
bbrock   That kit is what I installed. The roll pins that ...   Mar 17 2019, 10:57 PM
Mikey914   Yes the tool holds the pin so you can get it insta...   Mar 18 2019, 06:07 AM
bbrock   As far as the roll pins I actually used the ones ...   Mar 18 2019, 07:38 AM
Mikey914   Either way I'll take a look too this next week...   Mar 18 2019, 03:23 PM
Olympic 914   Bolted the seat rails to work table and used a wir...   Mar 18 2019, 05:08 PM
mepstein   Bolted the seat rails to work table and used a wi...   Mar 18 2019, 06:07 PM
914_7T3   Bolted the seat rails to work table and used a wi...   Apr 21 2019, 10:39 PM
- Lo-Fi Version Time is now: 18th September 2025 - 06:18 PM
