First Startup, Crank-By-Hand |
Chip |
Mar 19 2019, 10:38 AM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
I'm ready to crank the engine over for the first time in 30 yrs. (Lots of stories like this.) We've invited the neighborhood. I've changed the fuel lines, filter, cleaned pump, oil drain, tank, new sending unit, screen, topped off cylinders with MMO, cleaned plugs, etc. I'd like to turn the engine by hand, but don't know where to begin.
Any help, as I am alone and have no reference, alliance, resources or sanity. Thanks. (IMG:style_emoticons/default/agree.gif) |
ctc911ctc |
Mar 19 2019, 03:27 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Chip,
I started a garage find last year after 40 years of storage. STRONGLY recommend miracle oil in each cylinder and cranking the beast without Fuel or Plugs for 30-40 seconds and then stop. Wait 5 minutes and then again. Perhaps 10+ cycles of this. Get the oil pressure UP make it squeeze to the outer reaches This will not guarantee a healthy engine, but should protect the engine somewhat. Did I mention you should put some miracle oil in each cylinder........really,,,,,,do this....... GOOD LUCK WITH THE TEENER! I'm ready to crank the engine over for the first time in 30 yrs. (Lots of stories like this.) We've invited the neighborhood. I've changed the fuel lines, filter, cleaned pump, oil drain, tank, new sending unit, screen, topped off cylinders with MMO, cleaned plugs, etc. I'd like to turn the engine by hand, but don't know where to begin. Any help, as I am alone and have no reference, alliance, resources or sanity. Thanks. (IMG:style_emoticons/default/agree.gif) |
Chip |
Mar 20 2019, 12:14 AM
Chip, I started a garage find last year after 40 years of storage. STRONGLY recommend miracle oil in each cylinder and cranking the beast without Fuel or Plugs for 30-40 seconds and then stop. Wait 5 minutes and then again. Perhaps 10+ cycles of this. Get the oil pressure UP make it squeeze to the outer reaches This will not guarantee a healthy engine, but should protect the engine somewhat. Did I mention you should put some miracle oil in each cylinder........really,,,,,,do this....... GOOD LUCK WITH THE TEENER! Thanks so much. Tried to crank it today, but I don't think there is petrol getting to the engine. Fuel pump did not buzz upon turning key. The starter seemed ok, but no turnover. Need to check power to FP terminals, then see if pump is bad. I cleaned it out and hooked it up to a battery and it seemed ok. Can you provide a checklist for fuel, spark, etc? Thanks and thank you. ! I'm ready to crank the engine over for the first time in 30 yrs. (Lots of stories like this.) We've invited the neighborhood. I've changed the fuel lines, filter, cleaned pump, oil drain, tank, new sending unit, screen, topped off cylinders with MMO, cleaned plugs, etc. I'd like to turn the engine by hand, but don't know where to begin. Any help, as I am alone and have no reference, alliance, resources or sanity. Thanks. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 08:58 PM |
