Is there any rear caliper with e-brake & >38mm piston for 914/6GT ? |
amallagh |
Mar 16 2019, 07:06 AM
Member Group: Members Posts: 103 Joined: 4-September 06 From: Cheshire, England Member No.: 6,767 |
My 914/6GT is struggling a bit with brakes having uprated to a 2.8 twin plug with about 280bhp.
It currently has S calipers up front and some 914/6GT rears with Porterfield R4 pads. As well as heat the sticky track tyre set up could cope with more brake torque as well. (215/50r16 front and 245/45r16 rear). It is not a single use car - It is used on road as well as competitive rally and some trackdays. There are plenty of 911 uprate options for the front, but without changing to a 911 emergency brake on the rear, then I haven't been able to find something to balance things at the rear. The current set up is properly balanced and there is no point in uprating the front unless I can uprate the rear. I really don't want to mess about with the rear arms by fitting the 911 e-brake system unless I really have to. Is there any alternative rear caliper out there with a cable operated handbrake mechanism, with a >38mm piston like the original 914/6 calipers ? Anything from an Audi or VW for example that anyone knows will work in this application ? Something with a 42 mm piston (like the Carrera rears) or even slightly larger would be ideal. Or has anyone fitted larger discs to achieve a similar upgrade ? If I could uprate the rears, then I could fit some Boxster front calipers on 280mm Carrera discs or a Boxster caliper kit with larger 300mm discs which will still fit under my 16" wheels which I definitely want to keep. Am I wasting my time looking for an uprate option for the rears which still uses the 914/6 style cable operated handbrake in the calipers. The crucial things is not having to change everything over to a 911 style e-brake set up. Any advice/options very welcome. Regards Andrew |
amallagh |
Mar 26 2019, 07:25 PM
Thankyou for all the responces. The simple conclusion is that there appears to be no rear caliper available with >38mm pistons that has been adapted to work on the 914 rear arms in terms of caliper position and handbrake. Something with say a 42-45mm rear piston would open up a range of front alloy caliper uprate options that would be low cost to install.
The work to remove a perfectly set up pair of arms and strip to modify and weld to take a full set of 911 e brake parts and then repaint before refitting with new bearings, new discs, calipers and pads is a big job if you have to pay someone to do it. Probably around £3.5-4k for all the calipers (used), discs, pads, ebrake conversion kit, complete ebrake parts, bearings, painting, and labour including geometry set up. I have decided to compromise and just fit 3.2 Carrera front discs with refurbished 3.2 calipers with Ti pistons, heat shields and air ducts up front with just the std 914/6GT set up at the rear (refurbished) other than the uprated pads. Time will tell if I've done enough, but no point in uprating the front any further unless I can balance it with a matching uprate at the rear. Thankyou for all the advice Andrew |
Lo-Fi Version | Time is now: 12th June 2024 - 01:33 AM |
