| narino |
Mar 27 2019, 10:26 PM
Member ![]() ![]() Group: Members Posts: 234 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None
With the warm weather I've spent the last few days fixing wire connections and removing extraneous wires by the PO. A couple wires have me stumped, hoping for some help from the hive mind.
#1 - I have a heavy gauge red wire that is coming off the alternator, that the previous owner spliced into and ran through the longs to the hot terminal by the fuse box.
#2 - The PO ran heavy gauge red wires through the longs to the hot terminal by the fuse box.
#3 - I bought some pilot fog lights and went to install them and saw my horns are in the way.
Once I get these hot wires figured out I'll feel safer trying to start her and get her back on the road. Thanks in advance! (IMG:http://narino.com/images/wire%20to%20alt%2001%20sm.jpg) (IMG:http://narino.com/images/wire%20to%20longs%2001%20sm.jpg) (IMG:http://narino.com/images/horns%20sm.jpg) |
| ValcoOscar |
Mar 28 2019, 10:34 AM
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,604 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California
I'm in So Cal (90621). If you want drive down Sun AM we can possibly tackle your gremlins together.
I have lifts so we can easily get it up in the air. PM me Oscar |
narino Tracing wires & horn questions Mar 27 2019, 10:26 PM
Chi-town Wires in the longs = not stock
Horns = not stock
... Mar 27 2019, 10:43 PM
narino Thanks for the reply Chi-town.
Any idea about the... Mar 27 2019, 11:37 PM
Chi-town Usually the heavy wire goes to the starter positiv... Mar 28 2019, 12:01 AM
barefoot New alternator wiring harnesses are avaliable from... Mar 28 2019, 04:56 AM
narino Barefoot - Ahhhh... This explains a lot. I thought... Mar 28 2019, 09:47 AM
malcolm2 https://colorwiringdiagrams.com/t/porsche
I alwa... Mar 28 2019, 10:26 AM
narino malcolm2 - Funny, I just ordered these a few days ... Mar 28 2019, 11:48 AM
76-914 That Romex is priceless. :beer2: Mar 28 2019, 06:08 PM
bbrock The hole where the PO's wire runs through the ... Mar 28 2019, 07:31 PM
narino bbrock - Thank you! That hole by the dash was ... Mar 28 2019, 09:10 PM
narino Update and more questions.
Tested resistance to wi... Apr 3 2019, 12:56 PM
Dave_Darling
A while back a few wires to my headlight switch b... Apr 3 2019, 02:14 PM
narino Thank you @Dave_Darling . I had seen that articl... Apr 3 2019, 03:18 PM
bbrock Since it sounds like you'll be trying to use t... Apr 3 2019, 03:45 PM
narino Thanks @bbrock . I'm going to rebuild the al... Apr 3 2019, 06:33 PM
JeffBowlsby You can test the switches with this: Apr 3 2019, 09:16 PM
Dave_Darling The headlight switch is a switch--or rather, sever... Apr 3 2019, 09:23 PM
narino Jeff & Dave thank you so much! Apr 3 2019, 11:24 PM
narino Finally got all the supplies to build the cables. ... May 12 2019, 04:07 PM
76-914 IIRC, there is/are 1 or 2 small holes in that big ... May 12 2019, 04:58 PM
narino 76-914 - awesome possum, thank you! May 12 2019, 08:05 PM
narino A setback. After cleaning the fuse panel under the... May 31 2019, 05:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:56 PM |
