| narino |
Mar 27 2019, 10:26 PM
Member ![]() ![]() Group: Members Posts: 234 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None
With the warm weather I've spent the last few days fixing wire connections and removing extraneous wires by the PO. A couple wires have me stumped, hoping for some help from the hive mind.
#1 - I have a heavy gauge red wire that is coming off the alternator, that the previous owner spliced into and ran through the longs to the hot terminal by the fuse box.
#2 - The PO ran heavy gauge red wires through the longs to the hot terminal by the fuse box.
#3 - I bought some pilot fog lights and went to install them and saw my horns are in the way.
Once I get these hot wires figured out I'll feel safer trying to start her and get her back on the road. Thanks in advance! (IMG:http://narino.com/images/wire%20to%20alt%2001%20sm.jpg) (IMG:http://narino.com/images/wire%20to%20longs%2001%20sm.jpg) (IMG:http://narino.com/images/horns%20sm.jpg) |
| narino |
Mar 28 2019, 09:10 PM
bbrock - Thank you! That hole by the dash was going to bug me to no end. Glad I now know it was added by PO. Also per your reply I've rerouted the alternator wiring out of the J-tube hole.
Power wire in the harness: Good thought on possible resistance issue. I think that is what Chi-Town was insinuating, but I didn't pick up on it till now. I'll test for that tomorrow. Starter/Alt wire: Looking at the Flow Diagram I noticed the wire from battery to starter is labeled as 2.5mm. Yet the wire from starter to alternator is 6.0mm. Why wouldn't the wire back to the battery be sized 6.0mm? So glad to finally be finally figuring out these issues. Thanks everyone! (IMG:style_emoticons/default/beer.gif) |
narino Tracing wires & horn questions Mar 27 2019, 10:26 PM
Chi-town Wires in the longs = not stock
Horns = not stock
... Mar 27 2019, 10:43 PM
narino Thanks for the reply Chi-town.
Any idea about the... Mar 27 2019, 11:37 PM
Chi-town Usually the heavy wire goes to the starter positiv... Mar 28 2019, 12:01 AM
barefoot New alternator wiring harnesses are avaliable from... Mar 28 2019, 04:56 AM
narino Barefoot - Ahhhh... This explains a lot. I thought... Mar 28 2019, 09:47 AM
malcolm2 https://colorwiringdiagrams.com/t/porsche
I alwa... Mar 28 2019, 10:26 AM
narino malcolm2 - Funny, I just ordered these a few days ... Mar 28 2019, 11:48 AM
ValcoOscar I'm in So Cal (90621). If you want drive down... Mar 28 2019, 10:34 AM
76-914 That Romex is priceless. :beer2: Mar 28 2019, 06:08 PM
bbrock The hole where the PO's wire runs through the ... Mar 28 2019, 07:31 PM
narino Update and more questions.
Tested resistance to wi... Apr 3 2019, 12:56 PM
Dave_Darling
A while back a few wires to my headlight switch b... Apr 3 2019, 02:14 PM
narino Thank you @Dave_Darling . I had seen that articl... Apr 3 2019, 03:18 PM
bbrock Since it sounds like you'll be trying to use t... Apr 3 2019, 03:45 PM
narino Thanks @bbrock . I'm going to rebuild the al... Apr 3 2019, 06:33 PM
JeffBowlsby You can test the switches with this: Apr 3 2019, 09:16 PM
Dave_Darling The headlight switch is a switch--or rather, sever... Apr 3 2019, 09:23 PM
narino Jeff & Dave thank you so much! Apr 3 2019, 11:24 PM
narino Finally got all the supplies to build the cables. ... May 12 2019, 04:07 PM
76-914 IIRC, there is/are 1 or 2 small holes in that big ... May 12 2019, 04:58 PM
narino 76-914 - awesome possum, thank you! May 12 2019, 08:05 PM
narino A setback. After cleaning the fuse panel under the... May 31 2019, 05:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:57 PM |
