| 76-914 |
Mar 21 2019, 12:12 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
About 30 mins ago a guy called and asked if I wanted to buy his 86 Westy that needs an engine. You see where this is headed (IMG:style_emoticons/default/happy11.gif) I said no because I need to get rid of one project before taking on another. Mind you, this comes from a guy who's been spouting off about downsizing so he doesn't leave this mess should he unexpectedly depart this planet suddenly. (IMG:style_emoticons/default/rolleyes.gif) I tell my wife about the call and she tells me that I should do this. What should I look for when checking one of these out? Known gotcha's? Price ranges? Drive train will be converted to ...................drum roll pls................Yes, Subaru so I won't need VW engine or transmissions estimates. TIA, Kent
| strawman |
Mar 29 2019, 10:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 891 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California
I’ve had two Vanagon Westies: an ‘81 diesel full camper that I swapped an ‘85 1.8 gasser into, and an ‘86 Syncro Westy that I converted to weekender and swapped a ‘94 Legacy EJ22 engine into. Wish I still owned the Syncro mainly because they’re commanding such a premium price. I sold mine in 2005 for $9,900... (IMG:style_emoticons/default/dry.gif)
But to be honest, my TDI-swapped ‘93 Eurovan Westy (weekender) is better in every drivability measure: the A/C actually works, I can hear others talking while riding inside the van, I get 30mpg, the brakes stop the van, the seats are great, and it feels so much more solid. Of course, I also swapped in a correctly-geared 5-sp manual so I don’t have to dread another auto rebuild when I did the TDI swap. Parts prices and availability are not too bad; no worse than Vanagon stuff. I like Weekenders better than full campers because the side cabinet reduces the lower bed size, and the kitchen stuff is squeaky/clingy/heavy. The Cometic fridges are notoriously finicky, too. A propane stove and Yeti cooler are a better substitute IMHO. Another thing to look for is body seam rust on Vanagons. If you’re planning a Suby swap, the Kennedy full kit will get you a CARB smog badge to legally run in CA. |
| Tom_T |
Mar 31 2019, 11:54 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
If you’re planning a Suby swap, the Kennedy full kit will get you a CARB smog badge to legally run in CA. Is it still winking at you Kent!? (IMG:style_emoticons/default/confused24.gif) Kent & others looking at Engine Swaps - as noted above on the Kennedy Subies - I just noticed on the GoWesty upbuilt WBX-4's that they've added a new caution on the engines that they're not for CA on-road use (that was NOT on them up until recently). So CARB must've come down on them for not having CARB Smog approvals yet. So for Kent & others here in CA, I'd check with GoWesty to see if & when they plan to get CARB approval for their engine builds - & if they can. The WBX Vanagons are still subject to meeting Smog, & IIRC even the current bill in the CA Legislature to move the age up from 1975 only goes out to the early 1980's (the way-back-when original bill was to be a rolling 30 year, but the tree-huggers got it changed to 1975 cut-off). Current GoWesty Engine Choices - look at the "Emissions Info" tab for the warning note: 2200 cc - 8.81 CR with up to 102 hp & 135 ft.lbs of torque w/ GoWesty EFI* https://www.gowesty.com/product-details.php...type=Mechanical 2300 cc - 9.0:1 CR, with up to 114 hp & 157 ft.lbs of torque w/ GoWesty EFI* https://www.gowesty.com/product/rebuilt-eng...gine-?v=Vanagon 2450 cc - 9.4:1 CR, with up to 132 hp & 177 ft.lbs of torque w/ GoWesty EFI* https://www.gowesty.com/product/rebuilt-eng...gine-?v=Vanagon 2700 cc - 10:1 CR, with up to 162 hp & 197 ft-lbs of torque w/ GoWesty EFI* https://www.gowesty.com/product/rebuilt-eng...gine-?v=Vanagon $500 Add-on 48/48K mi Warranty (twice as long as was the 24/24 Factory Warr. new!) - https://www.gowesty.com/product/rebuilt-eng...grade?v=Vanagon * Apparently it's somewhat less HP & TQ if you stick with the factory Digifant EFI (only works up to 2450 cc) FYI for comparison with the above: Stock 1987-91 2.1L WBX is 9.0:1 CR, with 95 HP at 4800 rpm & 117 lbs/ft of Torque at 3200 rpm GoWesty Engine Article - https://www.gowesty.com/tech-article-details.php?id=31 GoWesty Vanagon Tech Articles - Incl for PPI Items - https://www.gowesty.com/tech-articles.php?l...mp;type=Vanagon GoWesty article: "Prices: "Cheap" Vanagons Are the Most Expensive" - https://www.gowesty.com/tech-article-details.php?id=17 Otherwise I'd recco using Tuttles in LA area, the engine rebuilder in the SoCal area which my longtime mechanic Hans has used since the early 1970s, & who rebuilt my `73 914's 2.0 ABX in the early 80's, & our `88 Westy's 2.1L WBX in 1999 (technically a new engine cuz a rod "holed" the top of the case at the right-rear corner of my original motor!). Tuttles would rebuild for CA street use to an officially legal 2.1L stock engine (with allowed overages for bigger rings etc. per factory & CARB specs), with a 12 month warranty. http://www.tuttlesvwparts.com/engines/ However, you might need to go through my guys at Hans Imports in Huntington Beach for the engine work to use them. Hans is still taking new Vanagon customers - but he will NOT take on any new 914 nor Aircooled customers - so don't ask them, but you can use my name/recco for Vanagons. http://www.hansimportsinc.com/ While IMHO the full camper is a better deal for us, & is fully self-contained & ready to go after traveling XC & camping in it with 2 kids & 2 adults for 31+/- years now, I will add a 48 Qt Icechest for the longer trips to augment the small fridge - which is 3-way (12v/110v/LP) & keeps cold, makes ice, & lasts a week+ on propane (I even keep it set-up to serve for post-disaster/earthquake for us at home). Another interesting Westy website - start here & then explore & see others listed FS, etc. - http://www.vwvanagoncamper.com/history/ . Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
76-914 SOT: A Westy Just Winked @ me Mar 21 2019, 12:12 PM
Chris H. :trophy: I can't help much on what to look for... Mar 21 2019, 12:58 PM
Tom_T Kent,
Your wife is right on! You can use th... Mar 21 2019, 03:09 PM
76-914 Excellant info Tom. The VW engine size increase ma... Mar 21 2019, 04:18 PM
Tom_T
Excellant info Tom. The VW engine size increase m... Mar 21 2019, 05:26 PM
rgalla9146 Common ailment,
'89 ...... for years now
... Mar 21 2019, 05:44 PM
preach Mine is an 85. My biggest gripe with it was the 1... Mar 21 2019, 05:47 PM
Tom_T
Mine is an 85. My biggest gripe with it was the ... Mar 21 2019, 06:25 PM
euro911 I had the old (170k mile) 1.9L rebuilt into a 2.1L... Mar 22 2019, 04:54 AM
veltror also just kampers
https://www.justkampers.com/vw-... Mar 31 2019, 08:22 AM
Tom_T
also just kampers
[url=https://www.justkampers.c... Mar 31 2019, 10:40 AM
euro911 How about this conversion?
It's a Oettinge... Mar 31 2019, 12:43 PM
Tom_T
It's a Oetting... Mar 31 2019, 02:32 PM
preach I like that Mark.
I have been getting ready for a... Mar 31 2019, 12:45 PM
r_towle Kent,
Wife said go for it.
Nuff said.
She is alway... Mar 31 2019, 06:17 PM
914Subaru
About 30 mins ago a guy called and asked if I wan... Dec 12 2020, 09:48 AM
76-914
About 30 mins ago a guy called and asked if I wa... Dec 12 2020, 10:00 AM
914Subaru
[quote name='914Subaru' post='2874251' date='Dec ... Dec 13 2020, 09:17 AM
76-914
[quote name='914Subaru' post='2874251' date='Dec... Dec 13 2020, 11:28 AM
914Subaru
[quote name='914Subaru' post='2874485' date='Dec ... Dec 13 2020, 11:44 AM
Bleyseng Go for the Subie swap as its a better engine by fa... Dec 12 2020, 10:02 AM
euro911 I may be putting 'Eileen' on the market in... Dec 12 2020, 11:37 AM
Chris H.
I may be putting 'Eileen' on the market i... Dec 12 2020, 03:13 PM
Montreal914 Cool thread with very nice information. Thank you ... Dec 12 2020, 01:36 PM
euro911 Hey Chris ... Other than just some local drives ar... Dec 12 2020, 08:20 PM
flat4guy Mark - let me know when you get ready as the wife ... Dec 12 2020, 08:43 PM
euro911 Mark - let me know when you get ready as the wife ... Jan 15 2021, 01:50 AM
racerbvd Saw this at Mecum a few years back.
[img]http:/... Jan 15 2021, 09:39 AM
flat4guy that's perfect Jan 18 2021, 07:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:15 PM |
