| bbrock |
Apr 2 2019, 10:01 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I searched and couldn't find an answer about where on a dished piston to measure the deck height. I have Euro spec Mahle "flat top" pistons for 8.0 compression, but in reality, they have a slight dish in them. I'm following Tom Wilson's book and he just says to measure them "at the crown."
I measured deck height with the single metal gasket/shims that came with the gasket kit installed only because they are already on there and I just wanted to see if I was close. Deck heights at the center range from .052" to .07" which seemed like a decent starting point but height out at the edges is only .02". Of course, I can get any number in between depending on where I measure. I just want to make sure I have the right clearance. Also, how important is it to cc and calculate precise compression for a street ride? I'm just looking for a reliable engine and not concerned about squeezing every HP out of the motor UNLESS it will improve fuel efficiency without sacrificing reliability. I'm happy to go through the drill if results in a better engine for my needs, but reading Wilson's book, it seems the important thing is to have enough clearance to keep the valves and piston tops safely apart. Finally, is it normal/acceptable/desireable to mix and match barrel base shims to even out variances in deck height? Any advice welcome. I just get confused trying to separate basic build best practices from performance tuning. |
| bbrock |
Apr 2 2019, 01:33 PM
Thanks guys. This is helpful. And yes, I do need to pull the jugs and clean up the registers. Thought I toss on a pic of the piston tops. These are the OEM Mahle pistons bought back when they were still cheap. The dish is quite subtle. I actually thought they were flat all these years until this morning when I started measuring. I caught the light so you can see it in the pic. I'm not sure it will add significantly to the combustion chamber volume, but we'll find out.
![]() This is Montana man, we run on buffalo tallow! Just keepin' it stock (IMG:style_emoticons/default/beer.gif) |
bbrock Measuring deck height on a dish Apr 2 2019, 10:01 AM
VaccaRabite Measure where the dish isn't. In this case it... Apr 2 2019, 12:27 PM
MarkV
Finally, is it normal/acceptable/desireable to ... Apr 2 2019, 12:39 PM
76-914 8:1? You running Kerosene? :evilgrin: Apr 2 2019, 12:54 PM
Mark Henry Not enough to worry about on a stock engine, IIRC ... Apr 3 2019, 05:29 AM
BeatNavy
Not enough to worry about on a stock engine, IIRC... Apr 3 2019, 06:26 AM
bbrock A new question/problem. I'll properly measure... Apr 3 2019, 11:35 AM
Mark Henry
A new question/problem. I'll properly measur... Apr 3 2019, 02:36 PM
cuddy_k Prob need to get the case decked. It's common ... Apr 3 2019, 12:25 PM
bbrock
Prob need to get the case decked. It's common... Apr 3 2019, 01:03 PM
Mark Henry
Prob need to get the case decked. It's commo... Apr 3 2019, 02:20 PM
cuddy_k dp Apr 3 2019, 12:25 PM
MarkV It's been a while since I did it. If I remembe... Apr 3 2019, 01:49 PM
bbrock Just to be clear, the "Barrel Height" I ... Apr 3 2019, 02:48 PM
bbrock Sorry, posted that last one before seeing Mark... Apr 3 2019, 02:55 PM
MarkV
Just to be clear, the "Barrel Height" I... Apr 3 2019, 03:02 PM
bbrock Well, after a lot of measuring and checking that I... Apr 16 2019, 09:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th September 2026 - 12:48 PM |
