| narino |
Mar 27 2019, 10:26 PM
Member ![]() ![]() Group: Members Posts: 234 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None
With the warm weather I've spent the last few days fixing wire connections and removing extraneous wires by the PO. A couple wires have me stumped, hoping for some help from the hive mind.
#1 - I have a heavy gauge red wire that is coming off the alternator, that the previous owner spliced into and ran through the longs to the hot terminal by the fuse box.
#2 - The PO ran heavy gauge red wires through the longs to the hot terminal by the fuse box.
#3 - I bought some pilot fog lights and went to install them and saw my horns are in the way.
Once I get these hot wires figured out I'll feel safer trying to start her and get her back on the road. Thanks in advance! (IMG:http://narino.com/images/wire%20to%20alt%2001%20sm.jpg) (IMG:http://narino.com/images/wire%20to%20longs%2001%20sm.jpg) (IMG:http://narino.com/images/horns%20sm.jpg) |
| Dave_Darling |
Apr 3 2019, 09:23 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The headlight switch is a switch--or rather, several switches in one housing. With one exception, the pins either contact other pins or don't, so the resistances you are looking for are "infinite" (no connection) or "zero" (dead short or close to it).
The one exception is the instrument light section, which has a rheostat--a variable resistor. All the below is from the 74 wiring diagram; other years may have differences. The headlight switch has three positions; in all the way, out one stop, out all the way. I have labeled those positions 0, 1, and 2 below. (Though I could have those backwards.) Pin 15: Should have no connection to any other pins in switch position 0 or 1. Should connect to 56 and 56K (only those) in switch position 2. Pin 30: Connect to 30b in switch position 0. Connect to pin 57 in switch position 1. Connect to 58L, 58R, K in switch positions 1 and 2. Pin 58a: No connectivity to any switch other than 58b. Variable resistance from 58a to 58b depending on knob rotation. --DD |
narino Tracing wires & horn questions Mar 27 2019, 10:26 PM
Chi-town Wires in the longs = not stock
Horns = not stock
... Mar 27 2019, 10:43 PM
narino Thanks for the reply Chi-town.
Any idea about the... Mar 27 2019, 11:37 PM
Chi-town Usually the heavy wire goes to the starter positiv... Mar 28 2019, 12:01 AM
barefoot New alternator wiring harnesses are avaliable from... Mar 28 2019, 04:56 AM
narino Barefoot - Ahhhh... This explains a lot. I thought... Mar 28 2019, 09:47 AM
malcolm2 https://colorwiringdiagrams.com/t/porsche
I alwa... Mar 28 2019, 10:26 AM
narino malcolm2 - Funny, I just ordered these a few days ... Mar 28 2019, 11:48 AM
ValcoOscar I'm in So Cal (90621). If you want drive down... Mar 28 2019, 10:34 AM
76-914 That Romex is priceless. :beer2: Mar 28 2019, 06:08 PM
bbrock The hole where the PO's wire runs through the ... Mar 28 2019, 07:31 PM
narino bbrock - Thank you! That hole by the dash was ... Mar 28 2019, 09:10 PM
narino Update and more questions.
Tested resistance to wi... Apr 3 2019, 12:56 PM
Dave_Darling
A while back a few wires to my headlight switch b... Apr 3 2019, 02:14 PM
narino Thank you @Dave_Darling . I had seen that articl... Apr 3 2019, 03:18 PM
bbrock Since it sounds like you'll be trying to use t... Apr 3 2019, 03:45 PM
narino Thanks @bbrock . I'm going to rebuild the al... Apr 3 2019, 06:33 PM
JeffBowlsby You can test the switches with this: Apr 3 2019, 09:16 PM
narino Jeff & Dave thank you so much! Apr 3 2019, 11:24 PM
narino Finally got all the supplies to build the cables. ... May 12 2019, 04:07 PM
76-914 IIRC, there is/are 1 or 2 small holes in that big ... May 12 2019, 04:58 PM
narino 76-914 - awesome possum, thank you! May 12 2019, 08:05 PM
narino A setback. After cleaning the fuse panel under the... May 31 2019, 05:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:57 PM |
