| ctc911ctc |
Feb 14 2019, 11:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,323 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear. I am thinking about installing a 2 post lift where each post would be against the walls, out of the way. I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift. 1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)? 2. How deep do the anchors need to be placed into the floor? Very little detail on web sites. 3. Are there any preferences as to vendors? I have been looking at this one: https://www.toolots.com/two-post-car-lift-l...#productDetails My requirements are that the lift be as small (footprint) and safe as possible. THANK YOU ALL TEENERS! CTC911CTC |
| 76-914 |
Apr 4 2019, 08:34 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I'm lucky there. My hose slips into the recess of the slabs expansion joint so the hose is semi recessed. The best accessory I have found for my Max Jack are the Harbor Freight small furniture dollies. They allow me to use the 4" extensions that come with it. Raise the car 3-4" then lower onto the dollies. Once on the dolly the extensions can be fitted. Why furniture dollies instead of blocks. Try it and you'll find out. Bottom line: Any lift is better than no lift. Get what you can afford and whatever fits. (IMG:style_emoticons/default/beerchug.gif)
ctc911ctc Lifts Feb 14 2019, 11:25 AM
BPic I have this one:
https://www.maxjaxusa.com/buy-pu... Feb 14 2019, 11:32 AM
mepstein The lift should have specific installation instruc... Feb 14 2019, 12:14 PM
ClayPerrine You are not going to get most two post lifts under... Feb 14 2019, 12:59 PM
ctc911ctc Not going to happen, brick carriage house, rebuild... Feb 14 2019, 01:02 PM
ClayPerrine They make a few short versions of the two post lif... Feb 14 2019, 04:00 PM
jvmarino Max Jax is pretty much your only option. That is w... Feb 14 2019, 07:18 PM
wndsnd I agree Max Jack is fantastic at that ceiling heig... Feb 14 2019, 07:35 PM
I agree Max Jack is fantastic at that ceiling hei... Feb 14 2019, 08:47 PM
rgolia
I agree Max Jack is fantastic at that ceiling hei... Feb 15 2019, 09:53 AM
cuddy_k Quick Jack is another great option. The lift secti... Feb 15 2019, 06:25 AM
mb911
Quick Jack is another great option. The lift sect... Feb 17 2019, 09:28 AM
ctc911ctc On my list - went to buy it today - price raised t... Apr 3 2019, 08:10 AM
mgphoto I decided on the EZ Car lift, light weight, very p... Feb 15 2019, 08:47 AM
ctc911ctc After carefully considering what was posted, my li... Feb 15 2019, 10:22 AM
John Each of the two Rotary lifts (7,000# and 10,000#) ... Feb 15 2019, 12:45 PM
Chi-town If you can't go up, what about down?
Cut the ... Feb 15 2019, 02:25 PM
Cut the... Feb 15 2019, 02:55 PM
ctc911ctc Good thing I am an engineer!
The concrete is ... Feb 15 2019, 08:07 PM
sithot
Expensive but possible an option. Might have to ... Feb 16 2019, 09:37 AM
Mark Henry There's a one post lift, plus it can be rolled... Feb 16 2019, 08:47 AM
burton73
There's a one post lift, plus it can be rolle... Feb 17 2019, 12:20 PM
There's a one post lift, plus it can be roll... Feb 17 2019, 03:27 PM
ledfoot
The Maxjax works with the 3” pad extension for... Feb 16 2019, 09:58 AM
ctc911ctc
The Maxjax works with the 3” pad extension fo... Feb 16 2019, 11:56 AM
r_towle
The Maxjax works with the 3” pad extension f... Feb 17 2019, 03:49 PM
[quote name='ctc911ctc' post='2689468' date='Feb ... Feb 17 2019, 04:02 PM
mb911
[quote name='ctc911ctc' post='2689468' date='Feb... Feb 17 2019, 04:21 PM
ClayPerrine
[quote name='mepstein' post='2689907' date='Feb 1... Feb 18 2019, 07:10 AM
[quote name='mepstein' post='2689907' date='Feb ... Feb 18 2019, 07:18 AM
ClayPerrine
[quote name='ClayPerrine' post='2690041' date='Fe... Feb 19 2019, 06:52 AM
Mark Henry
[quote name='ClayPerrine' post='2690041' date='Fe... Feb 20 2019, 02:37 PM
[quote name='ClayPerrine' post='2690041' date='F... Feb 20 2019, 02:44 PM
ClayPerrine
[quote name='Mark Henry' post='2690809' date='Feb... Feb 21 2019, 02:45 PM
sithot Bendpak:
https://www.bendpak.com/grandprix/ Feb 23 2019, 09:07 AM
steuspeed Single side option.
https://aclifts.com/lifts/m-... Feb 17 2019, 03:43 PM
AHudson
Quick Jack is another great option. The lift sect... Feb 18 2019, 07:57 AM
mepstein Any lift is better than jack stands. Feb 18 2019, 08:01 AM
North Coast Jim
All,
I am rebuilding the garage, very small NE g... Feb 18 2019, 11:19 AM
Triaddave If the ceiling is the limit on going up, build a p... Feb 18 2019, 12:41 PM
If the ceiling is the limit on going up, build a ... Feb 18 2019, 01:31 PM
cuddy_k Maxjax is a great option if you like/need to work ... Feb 18 2019, 01:30 PM
dan10101 When I turned 50 I petitioned for a rack. I chose... Feb 19 2019, 09:22 PM
ctc911ctc
When I turned 50 I petitioned for a rack. I chos... Feb 20 2019, 12:16 PM
TheWeatherMan
When I turned 50 I petitioned for a rack. I chos... Feb 26 2019, 02:11 PM
dr914@autoatlanta.com after looking at many many many lifts and lift man... Feb 23 2019, 09:51 AM
sithot
after looking at many many many lifts and lift ma... Feb 23 2019, 10:34 AM
mb911 Just bought a maxjax for 1500 today delivered.. Wa... Feb 26 2019, 05:31 PM
Just bought a maxjax for 1500 today delivered.. W... Feb 26 2019, 05:34 PM
DRPHIL914
Just bought a maxjax for 1500 today delivered.. W... Feb 27 2019, 08:19 AM
mb911
Just bought a maxjax for 1500 today delivered.. ... Feb 27 2019, 11:18 AM
Freezin 914 As some of you know, I just bought a mid rise lift... Feb 26 2019, 06:14 PM
Mark Henry One thing I don't like about some of the sciss... Feb 27 2019, 06:07 AM
Carl La Fong Mid size lifts are great. This garage has a 7 fo... Apr 3 2019, 10:15 AM
rhodyguy Welcome back Elliot! You've been missed ... Apr 3 2019, 11:22 AM
76-914
Welcome back Elliot! You've been missed ... Apr 3 2019, 12:52 PM
Carl La Fong
Welcome back Elliot! You've been missed ... Apr 3 2019, 02:46 PM
Mark Henry
Welcome back Elliot! You've been missed ... Apr 3 2019, 02:54 PM
Krieger
Welcome back Elliot! You've been missed ... Apr 3 2019, 10:41 PM
rhodyguy Man...that's a lot of quotes. Quote happy Wedn... Apr 3 2019, 01:01 PM
Carl La Fong I have no idea who you are all talking about. Apr 3 2019, 02:48 PM
sb914
I ... Apr 3 2019, 04:29 PM
Hans Zupp I have no idea who you are all talking about.I do... Apr 25 2019, 09:34 AM
914-300Hemi I just placed an order for a MaxJax 2 post lift. L... Apr 3 2019, 09:41 PM
mb911
I just placed an order for a MaxJax 2 post lift. ... Apr 4 2019, 05:46 AM
mlindner Ben, just get a cement blade for your circular saw... Apr 4 2019, 12:15 PM
914_teener
Ben, just get a cement blade for your circular sa... Apr 4 2019, 12:24 PM
mepstein Hose Protector Ramp - sold on Amazon Apr 4 2019, 12:26 PM
mlindner Ben, found a better shot before I filled the grove... Apr 4 2019, 12:26 PM
mlindner 914 teener. Bendpak, 6,000 lbs. love it. Apr 4 2019, 12:29 PM
mlindner ctc911ctc, just looking at your garage size again.... Apr 4 2019, 01:11 PM
914_teener
ctc911ctc, just looking at your garage size again... Apr 4 2019, 03:26 PM
Mark Henry
ctc911ctc, just looking at your garage size agai... Apr 5 2019, 06:10 AM
mlindner Just noticed, two out of the three two post lifts ... Apr 4 2019, 01:29 PM
mb911 @mlinder
I suppose I could do that.. Not a bad id... Apr 4 2019, 03:08 PM
Dredwin I embraced my hose...bought a pool noodle, cut it ... Apr 4 2019, 03:50 PM
mlindner 914 teener, good question and I do have a Cayman..... Apr 5 2019, 05:12 AM
mlindner I agree Mark, with doing that much work...trans, e... Apr 5 2019, 07:01 AM
Krieger Now I am considering the move to the two post lift... Sep 28 2019, 10:43 AM
ClayPerrine
Now I am considering the move to the two post lif... Sep 28 2019, 08:19 PM
914-d One of the lifts I have is 110v, the other is 220v... Sep 28 2019, 10:58 AM
mb911 The maxjax works on 110 .. I have used all kinds a... Sep 28 2019, 08:32 PM
oldschool I got this off of crags list its a tire chief has... Sep 29 2019, 01:07 AM
sithot A friend has put these in his latest dealership. ... Sep 29 2019, 05:39 AM
ClayPerrine
FWIW: It's apparently a little known fact t... Sep 29 2019, 12:21 PM
mb911 I need one that is about 48" might have to ma... Sep 29 2019, 12:52 PM
sithot
I need one that is about 48" might have to m... Sep 29 2019, 03:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:26 PM |
