Engine tin screws, Just need 4 |
rjames |
Apr 1 2019, 01:18 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
What size are these things? I just need four of them so I don't want to order a full set (which is how they are being sold by the various 914 vendors).
Literati914 |
Apr 4 2019, 08:30 AM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'd been thinking for a long time about trying some stainless "cap head" screws (rounded head / allen socket), rather than the more squared off shoulder of the original cheese heads .. (if I can find them in M6x12). Just think they'd look better - but is there any reason those would be a bad idea?
bbrock |
Apr 4 2019, 08:08 PM
I'd been thinking for a long time about trying some stainless "cap head" screws (rounded head / allen socket), rather than the more squared off shoulder of the original cheese heads .. (if I can find them in M6x12). Just think they'd look better - but is there any reason those would be a bad idea? Well, the original steel fasteners are pretty bad. Hard to imagine it getting much worse. I'm a bit of a stickler for originality but refuse to put those back in. But out of curiosity, I googled galvanic corrosion of stainless and aluminum. It seems an SS fastener in an aluminum block will be no problem, but an aluminum fastener in an SS block would be a big problem. |
bdstone914 |
Apr 5 2019, 08:05 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Brent You can get SS cheese head screws. I still find them PITA to remove and install in tight places. I am going to add blue Loctite to the ones I install in my engine. Wonder if anti seize will stop galvanic action or affect negatively the torque holding ability. Bruce Can you post that information about corrosion? Very interesting. Maybe the aluminum fastener is weaker? Thinking about the SS screws at the bottom of the bad pad that go through an aluminum sleeve. They corrode badly. Bruce Attached thumbnail(s) |
bbrock |
Apr 5 2019, 08:42 AM
Can you post that information about corrosion? Very interesting. Maybe the aluminum fastener is weaker? Thinking about the SS screws at the bottom of the bad pad that go through an aluminum sleeve. They corrode badly. Bruce Here's one of the sources and I found a couple others that said basically the same thing. https://www.bssa.org.uk/topics.php?article=89 It appears what is important is the ratio of cathode to anode. Since aluminum is the sacrificial anode in this pairing, a small aluminum fastener in a sea of receiving cathode will quickly corrode away to the point of failure. But in the reverse, the small amount of cathode in an SS fastener can't receive enough of the surrounding aluminum anode material to significantly damage it. I thought that was fastenating... see what I did there? (IMG:style_emoticons/default/lol-2.gif) Interesting idea on the SS cheese heads. Might be a good option for the most visible and accessible screws. I wondered the same about locktite or anti seize. |
jd74914 |
Apr 5 2019, 08:56 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Can you post that information about corrosion? Very interesting. Maybe the aluminum fastener is weaker? Thinking about the SS screws at the bottom of the bad pad that go through an aluminum sleeve. They corrode badly. Bruce Here's one of the sources and I found a couple others that said basically the same thing. https://www.bssa.org.uk/topics.php?article=89 It appears what is important is the ratio of cathode to anode. Since aluminum is the sacrificial anode in this pairing, a small aluminum fastener in a sea of receiving cathode will quickly corrode away to the point of failure. But in the reverse, the small amount of cathode in an SS fastener can't receive enough of the surrounding aluminum anode material to significantly damage it. I thought that was fastenating... see what I did there? (IMG:style_emoticons/default/lol-2.gif) Interesting idea on the SS cheese heads. Might be a good option for the most visible and accessible screws. I wondered the same about locktite or anti seize. I used standard antisieze (copper base IIRC) as a barrier and haven't had any issues with corrosion or loosening. In fact I took some out after 15+ years of install the other day and they were still tight, but unthreaded easily. Definitely a worthwhile change. I don't even want to think about how much time I spend drilling out the originals and retapping. (IMG:style_emoticons/default/barf.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:13 PM |
